I had to reinstall OSMC on my RP2. Since then OSMC does not find anything in my Network.
Laptop and Main PC are able to see each other and the files and also OSMC.
I tryed reinstalling OSMC again with no results.
Right now I’m using DHCP from the router for IP adresses. The SMB options are set to default (from clean install).
Does anybody have an Idea what I can try? I’m stuck.
Hi @BaseTea,
just to ensure to avoid confusion. You changed in Settings - Services - SMB Client - Maximum protocol version to SMBv1 and with that one change you are able to browse your network via Add Videos - Windows network (SMB)?
