Hi guys i have a raspberry pi 3 b+ i have installed on it pinns To install osmc and recabox both at the same time and having the possiblity To switch between them all went
ok after fews days problem begin osmc couldnt do update however space is fine i have 42 go available on the osmc partition but system wont do update
Can you help me there is some photo of situation
Thank you
Hard to say without logs, but I don’t know much about PINN.
The /media/root partition is 100% full.
====================== Diskspace =================== qZy25Yas
Filesystem Size Used Avail Use% Mounted on
devtmpfs 368M 0 368M 0% /dev
tmpfs 373M 15M 359M 4% /run
/dev/mmcblk0p10 58G 13G 42G 23% /
tmpfs 373M 0 373M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 373M 0 373M 0% /sys/fs/cgroup
/dev/mmcblk0p9 79M 29M 51M 36% /boot
/dev/mmcblk0p1 63M 52M 12M 83% /media/RECOVERY
/dev/mmcblk0p5 30M 14M 14M 50% /media/SETTINGS
/dev/mmcblk0p6 60M 7.9M 52M 14% /media/boot
/dev/mmcblk0p7 1.9G 1.9G 0 100% /media/root
/dev/mmcblk0p8 56G 52M 53G 1% /media/share
I know nothing about PINN, or what each partition should contain, but it seems that you need to change your partition sizes or install to a different partition, eg /media/share/.
