Right. I thought I’d give OSMC a try coming from OpenElec for half a year.
Main reason for OSMC was more nerdy control and more frequent updates.
My first ‘out of the box’ impressions. No need for SSH yet…
OSMC 2016.10-2
Installation went fine on my SD card. (Is there no easy way for multiboot OSMC/OpenElec on a single SD, with no partition sharing?)
Recognizing my HifiBerry Digi+ went fine. (First activate overlay in My OSMC!).
Mouse (Air Mouse) control I don’t like, yet. Almost impossible to navigate through vertical lists! Far too sensitive. Strange unintuitive behaviour, below or above middle… Never seen that before.
I have an Edimax Wifi dongle in the Pi and OSMC shows my 2.4GHz network on both dongle and Pi-internal, though which is which? wlan0 and wlan1? Does the wlan# indicate the hardware, internal/external?
It does see my 5GHz network on the Edimax but doesn’t react at all on a click? Region and band issue with my router?
For 2.4 GHz when I choose MyNetwork (wlan1) it always connects to MyNetwork (wlan0). Huh? -
It doesn’t browse my Synology NFS shares yet. Maybe my bad, on my NAS security/firewall (I also just changed most all my DHCP fixed mac assignments to something logical…). Ah yep, port forwarding on the router needed to catch up of course.
Ok, I can now browse OSMC to my NAS NFS share, but it won’t enter into subfolders or content… -
All ADD-ON’s so far give “Installation failed”??
The App Store in My OSMC does nothing when clicked??
My USB wireless keyboard was not recognized at one time. Reboot solved that.
Settings > Profiles = nothing clickable, weird.
My intention is to get VNC working, hopefully without SSH but that’s unlikely, shows Google.
NFS issues, Wifi issues, horrible mouse, no add-ons, no OSMC App Store.
Giving up for now. To be continued.
Third attempt works. ???
