i have OSMC (updatet to 2022 Version) running on Raspberry PI4 4GB.
My Audio is a bluetooth speaker. So, to get it running, i have to go to “MyOSMC”, there in ‘Bluetooth’ reconnect the (previously paired) Bluetooth speaker. Then exit MyOSMC,
select in Kodi System-Settings-audio-Bluetooth …
It is working until i switch off OSMC. When i start it again, i have to do the procedure
(MyOSMC /Bluetooth/reconnect… Kodi/System/Settings/Audio) again.
How i can make OSMC to remember the last audio setting?
OSMC/Kodi remembers your last audio setting. Your problem seems that your bluetooth speakers are not automatically reconnect.
You could try to pair/trust them to see if that helps.
As things stand, if your BT device isn’t connected when Kodi starts Kodi doesn’t know it’s there so can’t initiate a connection. I think it’s the same if you shut down your phone when it’s connected to a BT speaker. If not, we can look at getting Kodi to reconnect on start-up.
After booting the Pi, if you turn off your speaker and turn it on again, it will search for devices which trust it and connect to the Pi. Then you are good to go. This assumes that your speaker hasn’t connected to something else while the Pi was off.
If there’s nothing else for the speaker to do when the Pi is off, why leave it on? Just start the Pi, then the speaker and it will will work.
Edit: I just checked. When I turn my phone on I have to re-start BT but it does then connect to the device that it was connected to when I turned it off. So if that’s what people expect, we can have a look at that.
ok, but please, provide logs the next time. I’ll append some instructions in case this is not known.
reproduce the issue
