Hello. Pretty new to linux and having a go with raspi3.
My problem is that while OSMC reports wifi connection (i ping normally, used apt-get install wireless-tools since i couldnt iwconfig to workaround the wlan0 power off as some posts suggested), Kodi shows wifi Busy/Not connected and i can’t get any addons.
Tried to Update via MyOSMC as i’m writing those lines and its stuck on Starting Download.
Any suggestions?
Logs can be found here: http://paste.osmc.io/zevosajufe (i included my whole session)
