Under Confluence in Raspbmc I had a minor edit to the XML that allowed Shortcuts from Movie on the home screen to take me directly to:
USTVNow (Streaming)
TED Talks (Streaming)
Children (\tower\movies\children -> File Browse)
Comedy (\tower\movies\comedy -> File Browse)
Horror (\tower\movies\horror -> File Browse)
ETC
1 - How do I add direct shortcuts to File Browse items in OSMC?
2 - How do I setup the browse to do Folder/File Structure Navigation (rather than Artist/Year/Etc)?
Thanks HitcherUK. I have the direct shortcut LABELS, but I am having a heck of a time figuring out how to bind clicking on Children to take me to the folder \tower\movies\children
FYI, this contains
\tower\movies\children\9\9.iso
\tower\movies\children\a_christmas_story\a_christmas_story.iso
…etc
Under customize Movies I do a custom action:
ActivateWindows(files,“smb://TOWER/media/movies/”,return)
I get CLOSE to what I am after: the file browse for the movie collection… however this instead takes me to the file/share add dual screen under the file manager.
Once I figure out the custom action for MOVIES, then I will add a siiliar custom action to each movies submenu.
ActivateWindows(files,“smb://TOWER/media/movies/children”,return)
ActivateWindows(files,“smb://TOWER/media/movies/comedy”,return)
To me this sounds unnecessarily complicated, but maybe I am missing something?
Do you want to add e.g. a folder on your network share (that is added as a source) to the home screen?
Then just do this:
Browse to the folder (under videos/files)
Highlight folder and Context menu; Add to favourites
Go to Settings/Appearance/Skin-Settings
Customise Home Menu
Choose Add
Choose Shortcut; choose Favourite and the folder you previously added to Favourites
As Hithcher mentioned, if you d this you will also see what the command should be.
Personally I use smart playlists for such things instead, but sometimes it´s not optimal.
