Just noticed that if select the ‘use local build’ option in the OSMC installer you can use it to install the final build of raspbmc on a raspberry pi
That’s because all the image file is is a gziped disk image. You can also unzip the image and write it to disk using dd or win32diskimager.
You’ll find that the network configuration functions (pre-configuring Ethernet/Wifi settings) won’t work though using the OSMC installer as they are not stored in the same format.
Thanks for the info on how thats working. wasnt sure on the proper way to do it and i figured it would install
