The Installer hangs under certain circumstances, more due to my inexperience with using.
Given that many people will only want to run it once I feel it is appropriate to raise the issues I found even though it is not insurmountable.
I’m using Ubuntu 12.04LTS
$ uname -a
Linux Tosh 3.2.0-89-generic #127-Ubuntu SMP Tue Jul 28 09:28:33 UTC 2015 i686 i686 i386 GNU/Linux
I am new to OSMC and have used the installer a couple of times over a couple of weeks but each time it has tripped me up and resulted in the installer hanging.
I downloaded the Linux Installer and the relevant OSMC image for Raspberry Pi. On opening the Installer I follow the menu through Language and Device selection to the options for ‘what version…’ and ‘use local build…’ . I make the incorrect assumption that by selecting ‘local build’ I don’t have to select the version and click Next at which point the installer hangs and becomes unresponsive. It appears that if I select ‘local build’ before selecting a version the installer simply hangs.
I think the problem is a bit bigger so am going to reboot my machine, retest and add to this later.
No osmc.log in my home directory or anywhere on my machine…
$ sudo updatedb
$ locate osmc.log
However. there is this…
$ cat /var/log/syslog|grep osmc -i
Sep 1 17:54:48 Tosh gnome-session[2935]: WARNING: Unable to load desktop file '/usr/share/osmc/qt_host_installer.desktop': No such file or directory
Sep 1 17:54:48 Tosh gnome-session[2935]: WARNING: Unable to find desktop file 'gnome-/usr/share/osmc/qt_host_installer.desktop': Valid key file could not be found in search dirs
I can’t be sure exactly what I was doing at the time shown for these so they may/are probably not relevant as they are are not showing up now when I run through the installer to a hang. They may be the result of me killing processes while investigating what I could.
$sudo apt-get install osmc-installer
Reading package lists... Done
Building dependency tree
osmc-installer is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
I have at least one image file on the local machine…
$ ls Downloads/rasp/OSMC/ -hal
total 151M
drwxrwxr-x 2 peter peter 4.0K Aug 31 17:37 .
drwxrwxr-x 9 peter peter 4.0K Aug 31 17:34 ..
-rw-rw-r-- 1 peter peter 151M Aug 31 17:37 OSMC_TGT_rbp1_20150830.img.gz
On running the installer having selected Language and Device I get to version selection screen…
Scenario #1
Version Selected '201508-1' # of dropdown list (201508-1, 201507-1, 201506-1)
Local Build (Not Selected)
Next Selected
Result Continues to next Option
Scenario #2
Local Build Selected
Next Selected
Result Unresponsive
Scenario #3
Next Selected
Back Selected
Back Selected
Result Unresponsive
Does the selected ‘dropdown’ version have to match an available ‘local file’ version?
I did get the installer to run through and install from local file yesterday but can’t get it to do it today!
I have another machine running 14.04… I will try that shortly and see what happens.
This is the last couple of hours content and shuold contain several attempts…
(OSMC installer currently hung in the background)
Tue Sep 1 18:34:41 2015 OSMC Installer running on Linux
Tue Sep 1 18:34:41 2015 Detected locale as en_IE
Tue Sep 1 18:34:41 2015 Attempting to load translation for locale en_IE
Tue Sep 1 18:34:41 2015 Could not load translation!
Tue Sep 1 18:34:41 2015 Resolving a mirror
Tue Sep 1 18:34:41 2015 Resolved mirror to http://46.37.189.135/osmc/download/
Tue Sep 1 18:34:41 2015 Enumerating supported devices
Tue Sep 1 18:34:41 2015 Added the following devices
Tue Sep 1 18:34:41 2015 Vero
Tue Sep 1 18:34:41 2015 Raspberry Pi
Tue Sep 1 18:34:41 2015 Raspberry Pi 2
Tue Sep 1 18:34:41 2015 Checking for updates
Tue Sep 1 18:34:41 2015 Checking for updates by downloading http://46.37.189.135/osmc/download//installers/latest_linux
Tue Sep 1 18:34:42 2015 Acquired mirror file
Tue Sep 1 18:34:42 2015 No new update is available
Tue Sep 1 18:34:49 2015 The user has selected English as their language
Tue Sep 1 18:34:49 2015 The user has selected Raspberry Pi as their device
Tue Sep 1 18:34:49 2015 Attempting to download device versions file http://46.37.189.135/osmc/download/installers/versions_RBP
Tue Sep 1 18:34:49 2015 Found a build called 2015.08-1
Tue Sep 1 18:34:49 2015 Found a build called 2015.07-1
Tue Sep 1 18:34:49 2015 Found a build called 2015.06-1
Tue Sep 1 19:47:51 2015 OSMC Installer running on Linux
Tue Sep 1 19:47:51 2015 Detected locale as en_IE
Tue Sep 1 19:47:51 2015 Attempting to load translation for locale en_IE
Tue Sep 1 19:47:51 2015 Could not load translation!
Tue Sep 1 19:47:51 2015 Resolving a mirror
Tue Sep 1 19:47:51 2015 Resolved mirror to http://46.37.189.135/osmc/download/
Tue Sep 1 19:47:51 2015 Enumerating supported devices
Tue Sep 1 19:47:51 2015 Added the following devices
Tue Sep 1 19:47:51 2015 Vero
Tue Sep 1 19:47:51 2015 Raspberry Pi
Tue Sep 1 19:47:51 2015 Raspberry Pi 2
Tue Sep 1 19:47:51 2015 Checking for updates
Tue Sep 1 19:47:51 2015 Checking for updates by downloading http://46.37.189.135/osmc/download//installers/latest_linux
Tue Sep 1 19:47:52 2015 Acquired mirror file
Tue Sep 1 19:47:52 2015 No new update is available
Tue Sep 1 19:48:26 2015 The user has selected English as their language
Tue Sep 1 19:48:26 2015 The user has selected Raspberry Pi as their device
Tue Sep 1 19:48:26 2015 Attempting to download device versions file http://46.37.189.135/osmc/download/installers/versions_RBP
Tue Sep 1 19:48:27 2015 Found a build called 2015.08-1
Tue Sep 1 19:48:27 2015 Found a build called 2015.07-1
Tue Sep 1 19:48:27 2015 Found a build called 2015.06-1
Ubuntu 14.04 Works!
seems to be working fine, when I get to and select local build it opens the file manager and allows me to navigate to a file.
Ubuntu 12.04
I have done
$apt-get --purge remove osmc-installer and
$apt-get install osmc-installer
and it still hangs when I select local build
I cleared the log so this is a full ‘from open to hang’
$ cat log.txt
Tue Sep 1 21:04:55 2015 OSMC Installer running on Linux
Tue Sep 1 21:04:55 2015 Detected locale as en_IE
Tue Sep 1 21:04:55 2015 Attempting to load translation for locale en_IE
Tue Sep 1 21:04:55 2015 Could not load translation!
Tue Sep 1 21:04:55 2015 Resolving a mirror
Tue Sep 1 21:04:57 2015 Resolved mirror to http://46.37.189.135/osmc/download/
Tue Sep 1 21:04:57 2015 Enumerating supported devices
Tue Sep 1 21:04:57 2015 Added the following devices
Tue Sep 1 21:04:57 2015 Vero
Tue Sep 1 21:04:57 2015 Raspberry Pi
Tue Sep 1 21:04:57 2015 Raspberry Pi 2
Tue Sep 1 21:04:57 2015 Checking for updates
Tue Sep 1 21:04:57 2015 Checking for updates by downloading http://46.37.189.135/osmc/download//installers/latest_linux
Tue Sep 1 21:04:57 2015 Acquired mirror file
Tue Sep 1 21:04:57 2015 No new update is available
Tue Sep 1 21:05:09 2015 The user has selected English as their language
Tue Sep 1 21:05:09 2015 The user has selected Raspberry Pi as their device
Tue Sep 1 21:05:09 2015 Attempting to download device versions file http://46.37.189.135/osmc/download/installers/versions_RBP
Tue Sep 1 21:05:09 2015 Found a build called 2015.08-1
Tue Sep 1 21:05:09 2015 Found a build called 2015.07-1
Tue Sep 1 21:05:09 2015 Found a build called 2015.06-1
For the life of me I can’t remember (old age) what (if anything) I did differently yesterday because I did get it to run through once and image a card from a local file but I’m trying all variations I can think of to no avail.
I only recently completed some online courses in Python and believe me Sam I am no more than a novice.
Nothing would give me more pleasure than to be able to add something to this or any Open Source project but when I look at a git repository like this one, it’s a bit overwhelming. I can see dozens of individual files that I assume all make up the package (or part of) but its never obvious how they all hang together and usually the code is using advanced techniques I’ve not seen before.
Are there any Python elements I could at least look at to build some familiarity and is there is any area a novice Python programmer could get involved (with some mentoring from some patient others)?
While following your links and reading Debian’s documentation maybe I came across a small discrepancy that probably is not impacting anywhere and doesn’t warrant a PR but here goes…
This code references 'Section: tools"
am I right in saying that the Debian doesn’t have a section called “tools” but does have a section called “utils” https://packages.debian.org/testing/
