This is my first attempt at building a RPi system. At the time of error the entire build was these parts:
Raspberry Pi 2 Model B Project Board - 1GB RAM - 900 MHz Quad-Core CPU
https://www.amazon.ca/gp/product/B00OY7HR1U/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
SD card is a samsung EVO 16gb
It failed to booth both with and without the ethernet cable plugged in. It has failed to boot with and without a keyboard or mouse plugged in. I used SD Formaater 4.0 to format the SD card and I have installed OSMC with it using both the self-executing file or by directly mounting the image to the disk.
I get the same error in every instance: “Kernel Panic - not syncing: No init found… blah blah init.txt”
Is there some way I can capture some boot data to post here?
Thanks in advance for the help.
