Hi there,
I’ve just installed OSMC on my Raspberry Pi 3 but I cannot play any media located on my network drives on Windows 10 or on the SD Card.
This part below is not really relevant but it might be interesting too:
First of all, I wanted to mount with SMB but I keep having the same message “Operation not permitted”.
I’ve seen countless threads with this problem and I’ve tried a lot of manipulations, no luck from now. It seems that Samba is now restricted, and I tried to change with protocol v1, v2 and nothing relevant appeared. (it’s working perfectly with my Galaxy S7 and Es Explorer, and another computer on Windows 10, so it’s probably a bug in OSMC).
So, I’ve decided to change how I access my network shares, so with SSH I have mounted them with:
sudo mount -t cifs //192.168.1.1/Series\ Matthieu Series\ Matthieu/
Anyway,
I can now access to them in console or GUI but when the playback start, well the screen just stops! To be sure, I have copied directly on the SD card (Sandisk Ultra class 10) some files, with various size and codecs (SD, 720p, h264) and it still freezing
I have uploaded some logs here:
https://paste.osmc.tv/ecoqasiyow
When I start playing, and if I connect with SSH and execute top, I can see that the CPU is around 6% for a good old It Crowd (180 MB file). One more thing, I am streaming audio to my Bluetooth Speakers because the Video Output is a DLP projector without sound.
I have reverted to “standard” profile, no turbo mode: same thing.
Any help would be greatly appreaciated
