Hello,
i’m using osmc with kody 15.
My problem is, that my wifi dosn’t automatically connect to the router after reboot or shut down and restart.
After every start i have to connect to the wlan from hand.
Is there an opportunity for an automatic connection for wlan?
Hanimaniac
OSMC will automatically attempt to connect when it boots, and also periodically (every few minutes) if it can see the network but is not connected.
If it is not connecting automatically that is because it is having difficulty doing so. We would need to see the system journal log from My OSMC log uploader to have any hope of knowing what the cause might be, but it is most likely a signal issue.
Thanks for the Answer.
Here is my log
http://paste.osmc.io/qoyorigiya
