Im trying to get my gamepad (USB Wired) working with osmc kodi navigation. I know osmc kodi 16 is explicitly compiled with --disable-sdl --disable-joystick.
I tried setup my gamepad with this tutorial
I have used mapping software joymap-0.3, I have tested the maping file with jstest all worked. Every thing should be working fine but … If im not in kodi all works, but when i start kodi my gamepad doesn’t respond and jstest (from ssh) is not showing anything. I think Kodi is blocking /dev/input/js0. I tried Kodi 17 test builds this doesn’t acure there but still i could not make my gamepad working. I tried to install kodi from http://pipplware.pplware.pt but i couldn’t swap kodi packages. Is there kodi packages for osmc with working gamepad. I know that DEV Team is working on integrating RetroPlayer that will have new system implemented but still it’s realy unknown when it will happen. Any help would be appriciated.
Hi. Kodi indeed blocks input for joypads if it doesn’t run on x11.
This is known and expected behaviour according to @DBMandrake.
I am not sure why the sdl-joystick option is not enabled probably to not have a depenency on sdl.
A xboxcontroller should still work.
Installing kodi from a different repository defeats the purpose of osmc.
You would probably better install kodi on raspbian or retropie and run it atop x11 if you desperately need joypad input.
Or @sam_nazarko could activate generic usb joypads to be usable in kodi if thats possible.
Retroplayer will come with version 18 so i doubt there will be any builds with sdl however if @sam_nazarko has the time he might update his retroplayer test builds
Try build it with --enable-joystick and I will merge it if it doesn’t cause ill effect. I would recommend we look at support for this with v17 builds, rather than Jarvis. Adding the gamepad addon may be enough.
