Using a RP3 and looking at PVR tv.
When i use kodi 16 its show a quick “working” down the right corner and then nothing happens.
But if i install kodi 17 beta from LibreElec it works fine! so nothing is wrong with the stream or with the RP3. Any clue what it could be?
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
