anyone knows this problem?
connect via WLAN , but GATEWAY is not stored.
WLAN connection disappears and is not persistent.
does anyone knows where the network settings are stored in conman?
Thanks for the hints
Haven’t heard about that
/etc/connman.conf
/etc/connman.prefs
/var/lib/connman/wifi*
Issues like this can occur if you run wired and wireless at the same time.
ok that is maybe the problem. I had both wlan and lan
Hi , buy I do not see the IP settings in /etc/connman.conf
where are they?
ok found it now. thanks
