Hello Sam and Team,
any chance that I could help with My OSMC application translation to Czech? Right now, XMBC is localized very well, at least Czech.
I was looking into GitHub repo and found english string files for the osmcsetting module. If I send/commit them translated, will you include them in next build ?
thank you, but OSMC has already generated locale, anyways I have run the locale generation again and there is no change. I still have Czech XBMC and english “My OSMC” plugin. So asking again, if I translate “My OSMC” strings, will you integrate it?
Yep. The strings.po files haven’t been pruned for redundant strings yet, so there may be some that arent needed. And of course new strings may be added in the future (this is RC not a full release). But if you can translate I can roll those files in if needed.
Each of the sub menu items is a different addon module. Just look for the strings.po file under resources/language/English and change the msgstr (not msgid) for each module.
Thank you Karnage, I have found time to translate the localization, finally… Do I need to build whole OSMC into an image to test out the resources? Or I can just build and deploy media center-addon-osmc package?
