Hello,
I have connected an folder via network and sporadic OSMC (2019-5-1) lost the connection. Attached over sftp.
Log is there
https://paste.osmc.tv/hadeluhifi
It worked stable with the last 17.x version
Hello,
Log is there
Can you please enable debugging and re-upload the log?
Suggest to check the ssh log on the Pi
2019-05-23 06:31:33.804 T:1484456672 ERROR: AddOnLog: SFTP support: SFTPSession: Not connected, can't list directory 'media/pi/Elements/' 2019-05-23 06:31:33.804 T:1484456672 ERROR: GetDirectory - Error getting sftp|ssh://USERNAME:PASSWORD@192.168.178.46:22/media/pi/Elements/
Also suggest to enable debugging log in to on OSMC
And as usual suggest to check network stability with iperf3 and maybe also scp on command line
Even if OSMC says it can’t connect SSH or SCP are working
Well if you have issue from within Kodi it is always good to check from command line first. Because than you can exclude that it is a Kodi issue
I had to, there aren’t any options to make a log without cli.
On OSMC you mean?
Yes
Via MyOSMC - Log Uploader
Anyhow check iperf3 and scp from command line to get to the source of your problem
Good to know, i will take a look at it with iperf3
New log
https://paste.osmc.tv/imosavimaj
and iperf
osmc@osmc:~$ iperf3 -R -c 192.168.178.46
Reverse mode, remote host 192.168.178.46 is sending
[ 4] local 192.168.178.28 port 47890 connected to 192.168.178.46 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 12.1 MBytes 101 Mbits/sec
[ 4] 1.00-2.00 sec 13.0 MBytes 109 Mbits/sec
[ 4] 2.00-3.00 sec 12.8 MBytes 107 Mbits/sec
[ 4] 3.00-4.00 sec 12.8 MBytes 107 Mbits/sec
[ 4] 4.00-5.00 sec 11.6 MBytes 97.7 Mbits/sec
[ 4] 5.00-6.00 sec 13.3 MBytes 111 Mbits/sec
[ 4] 6.00-7.00 sec 13.4 MBytes 112 Mbits/sec
[ 4] 7.00-8.00 sec 13.4 MBytes 112 Mbits/sec
[ 4] 8.00-9.00 sec 13.4 MBytes 112 Mbits/sec
[ 4] 9.00-10.00 sec 13.2 MBytes 111 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 132 MBytes 111 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 132 MBytes 111 Mbits/sec receiveriperf Done.
and
osmc@osmc:~$ iperf3 -c 192.168.178.46
Connecting to host 192.168.178.46, port 5201
[ 4] local 192.168.178.28 port 47894 connected to 192.168.178.46 port 5201
[ 4] 0.00-1.00 sec 8.11 MBytes 68.0 Mbits/sec 0 100 KBytes
[ 4] 1.00-2.00 sec 8.43 MBytes 70.7 Mbits/sec 0 113 KBytes
[ 4] 2.00-3.00 sec 8.70 MBytes 73.0 Mbits/sec 0 113 KBytes
[ 4] 3.00-4.00 sec 9.09 MBytes 76.3 Mbits/sec 0 119 KBytes
[ 4] 4.00-5.00 sec 8.01 MBytes 67.2 Mbits/sec 2 96.2 KBytes
[ 4] 5.00-6.00 sec 8.68 MBytes 72.8 Mbits/sec 0 110 KBytes
[ 4] 6.00-7.00 sec 7.93 MBytes 66.5 Mbits/sec 0 110 KBytes
[ 4] 7.00-8.00 sec 7.71 MBytes 64.7 Mbits/sec 0 116 KBytes
[ 4] 8.00-9.00 sec 7.31 MBytes 61.3 Mbits/sec 1 94.7 KBytes
[ 4] 9.00-10.00 sec 7.99 MBytes 67.0 Mbits/sec 0 99.0 KBytes
[ 4] 0.00-10.00 sec 82.0 MBytes 68.7 Mbits/sec 3 sender
[ 4] 0.00-10.00 sec 81.8 MBytes 68.6 Mbits/sec receiveriperf Done.
the smb connection worked well…
The iperf3 values looks OK even so some retries look high.
Not sure what the relay to SMB is. Did you tried scp from command line?
You mean from OSMC to the server?
No from server to OSMC, same direction as if you play it in Kodi
