This is the Kodi.log, I don’t see something wrong in it … Do you want other logs?
14:39:25.374 T:1958633472 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:39:25.374 T:1958633472 NOTICE: -----------------------------------------------------------------------
14:39:25.374 T:1958633472 NOTICE: Starting Kodi (17.5). Platform: Linux ARM (Thumb) 32-bit
14:39:25.374 T:1958633472 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
14:39:25.374 T:1958633472 NOTICE: Kodi compiled Oct 29 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
14:39:25.375 T:1958633472 NOTICE: Running on Open Source Media Center 2017.10-1, kernel: Linux ARM 32-bit version 4.9.29-10-osmc
14:39:25.375 T:1958633472 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
14:39:25.375 T:1958633472 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
14:39:25.375 T:1958633472 NOTICE: ARM Features: Neon disabled
14:39:25.375 T:1958633472 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
14:39:25.375 T:1958633472 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
14:39:25.375 T:1958633472 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
14:39:25.375 T:1958633472 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
14:39:25.375 T:1958633472 NOTICE: special://envhome/ is mapped to: /home/osmc
14:39:25.375 T:1958633472 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
14:39:25.375 T:1958633472 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
14:39:25.375 T:1958633472 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
14:39:25.376 T:1958633472 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
14:39:25.376 T:1958633472 NOTICE: Local hostname: ZABO-PI
14:39:25.376 T:1958633472 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
14:39:25.376 T:1958633472 NOTICE: -----------------------------------------------------------------------
14:39:25.597 T:1958633472 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
14:39:25.626 T:1958633472 NOTICE: load settings...
14:39:25.962 T:1958633472 NOTICE: Found 2 Lists of Devices
14:39:25.963 T:1958633472 NOTICE: Enumerated PI devices:
14:39:25.963 T:1958633472 NOTICE: Device 1
14:39:25.963 T:1958633472 NOTICE: m_deviceName : HDMI
14:39:25.963 T:1958633472 NOTICE: m_displayName : HDMI
14:39:25.963 T:1958633472 NOTICE: m_displayNameExtra:
14:39:25.963 T:1958633472 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
14:39:25.963 T:1958633472 NOTICE: m_channels : FL,FR
14:39:25.963 T:1958633472 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
14:39:25.964 T:1958633472 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
14:39:25.964 T:1958633472 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
14:39:25.964 T:1958633472 NOTICE: Device 2
14:39:25.964 T:1958633472 NOTICE: m_deviceName : Analogue
14:39:25.964 T:1958633472 NOTICE: m_displayName : Analogue
14:39:25.964 T:1958633472 NOTICE: m_displayNameExtra:
14:39:25.964 T:1958633472 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:39:25.964 T:1958633472 NOTICE: m_channels : FL,FR
14:39:25.964 T:1958633472 NOTICE: m_sampleRates : 48000
14:39:25.964 T:1958633472 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
14:39:25.964 T:1958633472 NOTICE: m_streamTypes : No passthrough capabilities
14:39:25.964 T:1958633472 NOTICE: Device 3
14:39:25.964 T:1958633472 NOTICE: m_deviceName : Both
14:39:25.964 T:1958633472 NOTICE: m_displayName : HDMI and Analogue
14:39:25.965 T:1958633472 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:39:25.965 T:1958633472 NOTICE: m_channels : FL,FR
14:39:25.965 T:1958633472 NOTICE: m_sampleRates : 48000
14:39:25.965 T:1958633472 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
14:39:25.965 T:1958633472 NOTICE: m_streamTypes : No passthrough capabilities
14:39:25.965 T:1958633472 NOTICE: Enumerated ALSA devices:
14:39:25.965 T:1958633472 NOTICE: Device 1
14:39:25.965 T:1958633472 NOTICE: m_deviceName : @
14:39:25.965 T:1958633472 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
14:39:25.965 T:1958633472 NOTICE: m_displayNameExtra:
14:39:25.965 T:1958633472 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
14:39:25.965 T:1958633472 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
14:39:25.997 T:1958633472 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
14:39:25.998 T:1958633472 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Do not modify! These are OSMC Optimised Settings for your device !-->
<!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !-->
<!-- It will override these settings, and your settings will be preserved across OSMC updates !-->
<advancedsettings>
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
<handlemounting>0</handlemounting>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
14:39:26.004 T:1958633472 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
14:39:26.004 T:1958633472 NOTICE: Contents of special://profile/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<videodatabase>
<name>KODI-video</name>
<host>XX.XX.XX.XX</host>
<user>kodi</user>
<pass>*****</pass>
<type>mysql</type>
<port>3307</port>
</videodatabase>
<musicdatabase>
<name>KODI-music</name>
<user>kodi</user>
<pass>*****</pass>
<type>mysql</type>
<port>3307</port>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
14:39:26.004 T:1958633472 WARNING: VIDEO database configuration is experimental.
14:39:26.006 T:1958633472 NOTICE: Default Video Player: VideoPlayer
14:39:26.007 T:1958633472 NOTICE: Default Audio Player: paplayer
14:39:26.007 T:1958633472 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:39:26.007 T:1958633472 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:39:26.007 T:1958633472 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
14:39:26.010 T:1958633472 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:39:26.018 T:1958633472 NOTICE: Loaded playercorefactory configuration
14:39:26.019 T:1958633472 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:39:26.019 T:1958633472 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:39:26.326 T:1958633472 NOTICE: Running database version Addons27
14:39:28.099 T:1958633472 NOTICE: ADDONS: Using repository repository.xbmc.org
14:39:28.099 T:1958633472 NOTICE: ADDONS: Using repository repository.zomboided.plugins
14:39:28.099 T:1958633472 NOTICE: ADDONS: Using repository repository.xvbmc
14:39:28.224 T:1958633472 WARNING: Unable to resolve: /inputstream.rtmp.so.1.0.4.SC get_addon, reason: /home/osmc/.kodi/addons/inputstream.rtmp/inputstream.rtmp.so.1.0.4.SC: undefined symbol: get_addon
14:39:28.225 T:1958633472 ERROR: Unable to resolve exports from dll /home/osmc/.kodi/addons/inputstream.rtmp/inputstream.rtmp.so.1.0.4.SC
14:39:29.047 T:1958633472 NOTICE: Raspberry PI firmware version: Sep 22 2017 21:36:43
Copyright (c) 2012 Broadcom
version f5217b8887607d0dd890a434de9c73d9aa9a7c0f (clean) (release)
14:39:29.048 T:1958633472 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
14:39:29.048 T:1958633472 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
14:39:29.050 T:1958633472 NOTICE: Config:
arm_freq=900
audio_pwm_mode=1
config_hdmi_boost=5
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x1b774
over_voltage_avs_boost=0x1e848
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
sdtv_aspect=1
second_boot=1
temp_limit=85
14:39:29.051 T:1958633472 NOTICE: Config:
device_tree=-
14:39:29.072 T:1958633472 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
14:39:29.077 T:1958633472 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
14:39:29.077 T:1958633472 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
14:39:29.078 T:1958633472 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
14:39:29.078 T:1958633472 NOTICE: Found (1920x1080@60.000000) at 28, setting to RES_DESKTOP at 16
14:39:29.079 T:1958633472 NOTICE: Checking resolution 16
14:39:29.409 T:1958633472 NOTICE: GL_VENDOR = Broadcom
14:39:29.409 T:1958633472 NOTICE: GL_RENDERER = VideoCore IV HW
14:39:29.409 T:1958633472 NOTICE: GL_VERSION = OpenGL ES 2.0
14:39:29.409 T:1958633472 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
14:39:29.409 T:1958633472 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
14:39:32.123 T:1937765360 NOTICE: Running database version Addons27
14:39:32.128 T:1937765360 NOTICE: Running database version ViewModes6
14:39:32.134 T:1937765360 NOTICE: Running database version Textures13
14:39:32.161 T:1830810608 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
14:39:34.500 T:1937765360 NOTICE: Running database version KODI-music60
14:39:37.565 T:1937765360 NOTICE: Running database version KODI-video107
14:39:37.602 T:1937765360 NOTICE: Running database version TV29
14:39:37.605 T:1937765360 NOTICE: Running database version Epg11
14:39:37.609 T:1958633472 NOTICE: start dvd mediatype detection
14:39:40.077 T:1958633472 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:39:49.965 T:1958633472 NOTICE: initialize done
14:39:49.965 T:1958633472 NOTICE: Running the application...
14:39:49.976 T:1958633472 NOTICE: starting zeroconf publishing
14:39:49.977 T:1958633472 NOTICE: CWebServer[8080]: Started
14:39:49.977 T:1958633472 NOTICE: starting upnp client
14:39:49.983 T:1605366768 NOTICE: ES: Starting UDP Event server on port 9777
14:39:49.983 T:1605366768 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
14:39:59.978 T:1689252848 ERROR: EXCEPTION: Unknown addon id 'repository.colossus'.
14:39:59.996 T:1689252848 NOTICE: [Covenant] ######################### COVENANT ############################
14:39:59.996 T:1689252848 NOTICE: [Covenant] ####### CURRENT COVENANT VERSIONS REPORT ######################
14:39:59.996 T:1689252848 NOTICE: [Covenant] ### ERROR GETTING COVENANT VERSIONS - NO HELP WILL BE GIVEN AS THIS IS NOT AN OFFICIAL COVENANT INSTALL. ###
14:39:59.996 T:1689252848 NOTICE: [Covenant] ###############################################################
14:39:59.998 T:1680864240 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-17.5), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
14:40:06.913 T:1734341616 WARNING: CSkinInfo: failed to load skin settings
14:40:13.253 T:1805472752 ERROR: OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
14:42:52.427 T:1937765360 WARNING: CSkinInfo: failed to load skin settings
14:42:58.314 T:1958633472 NOTICE: VideoPlayer: Opening: http://a1.phobos.apple.com/us/r1000/000/Features/atv/AutumnResources/videos/b1-4.mov
14:42:58.314 T:1958633472 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:42:58.414 T:1567364080 NOTICE: Creating InputStream
14:42:59.043 T:1567364080 NOTICE: Creating Demuxer
14:43:00.502 T:1567364080 NOTICE: Opening stream: 0 source: 256
14:43:00.502 T:1567364080 NOTICE: Creating video codec with codec id: 28
14:43:00.525 T:1567364080 NOTICE: Creating video thread
14:43:00.525 T:1471149040 NOTICE: running thread: video_thread
14:43:01.196 T:1567364080 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
14:44:07.829 T:1471149040 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
14:45:04.564 T:1918890992 WARNING: Previous line repeats 1 times.
14:45:04.565 T:1918890992 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:2205)
