Hai Guys,
i’m using OSMC in Raspberry Pi:
here are my versions:
osmc@osmc:~$ grep Kodi .kodi/temp/kodi.log | head -3
2022-04-11 22:04:51.788 T:901 INFO <general>: Starting Kodi (19.4). Platform: Linux ARM (Thumb) 32-bit
2022-04-11 22:04:51.788 T:901 INFO <general>: Using Release Kodi x32
2022-04-11 22:04:51.788 T:901 INFO <general>: Kodi compiled 2022-03-08 by GCC 8.3.0 for Linux ARM (Thumb) 32-bit version 5.10.78 (330318)
osmc@osmc:~$ grep VERSION_ID /etc/os-release
VERSION_ID="2022.03-1"
I updated the OSMC OTA few days ago.
and my Movies collection are in windows 10 & uses WinNFSd as the NFS server for OSMC to connect.
I noticed that the updated one is using nfs4 by default, while the older one isn’t. CMIIW. since when uses the old one i didn’t have to use nfsvers=3 in fstab to mount from winnfsd to osmc.
my fstab:
192.168.2.2:/Video /home/osmc/Movies nfs ro,async,nolock,noauto,x-systemd.automount,nfsvers=3 0 0
but now when updated eventhough the connection was successful, it hangs sometimes. so i need to manually remount the nfs shares again and sometimes need to reboot the raspberry pi or the winnfsd server.
when hangs i can’t ls the mount dir but after remount i can do ls to mount dir:
osmc@osmc:~$ ls Movies
^C
osmc@osmc:~$ sudo umount Movies
osmc@osmc:~$ sudo mount -v Movies
mount.nfs: timeout set for Mon Apr 11 22:23:24 2022
mount.nfs: trying text-based options 'nolock,nfsvers=3,addr=192.168.2.2'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: trying 192.168.2.2 prog 100003 vers 3 prot TCP port 2049
mount.nfs: prog 100005, trying vers=3, prot=17
mount.nfs: trying 192.168.2.2 prog 100005 vers 3 prot UDP port 1058
'(6) Guitar Backing Track Rock Ballad - C# minor - YouTube.MP4'
AnyDesk
'Apex.2021.HDRip.XviD.AC3-EVO[TGx]'
CamStudio
Captures
the mount always hangs after 1h time more or less.
any idea or anyone has the same issue as mine?
Thanks in advances
