Yes I tried with USB PnP Sound Device, Analog
This is a part of my log:
2021-08-19 13:32:58.144 T:427 INFO <general>: -----------------------------------------------------------------------
2021-08-19 13:32:58.144 T:427 INFO <general>: Starting Kodi (19.1). Platform: Linux ARM (Thumb) 32-bit
2021-08-19 13:32:58.144 T:427 INFO <general>: Using Release Kodi x32
2021-08-19 13:32:58.144 T:427 INFO <general>: Kodi compiled 2021-07-15 by GCC 8.3.0 for Linux ARM (Thumb) 32-bit version 5.10.22 (330262)
2021-08-19 13:32:58.144 T:427 INFO <general>: Running on BCM2835 with Open Source Media Center 2021.08-1, kernel: Linux ARM 32-bit version 5.10.32-2-osmc
2021-08-19 13:32:58.190 T:427 INFO <general>: FFmpeg version/source: 4.3.2-Kodi
2021-08-19 13:32:58.190 T:427 INFO <general>: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2021-08-19 13:32:58.190 T:427 INFO <general>: ARM Features: Neon disabled
2021-08-19 13:32:58.190 T:427 INFO <general>: special://xbmc/ is mapped to: /usr/share/kodi
2021-08-19 13:32:58.190 T:427 INFO <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2021-08-19 13:32:58.190 T:427 INFO <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2021-08-19 13:32:58.190 T:427 INFO <general>: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
2021-08-19 13:32:58.190 T:427 INFO <general>: special://envhome/ is mapped to: /home/osmc
2021-08-19 13:32:58.190 T:427 INFO <general>: special://home/ is mapped to: /home/osmc/.kodi
2021-08-19 13:32:58.190 T:427 INFO <general>: special://temp/ is mapped to: /home/osmc/.kodi/temp
2021-08-19 13:32:58.190 T:427 INFO <general>: special://logpath/ is mapped to: /home/osmc/.kodi/temp
2021-08-19 13:32:58.190 T:427 INFO <general>: The executable running is: /usr/lib/kodi/kodi.bin
2021-08-19 13:32:58.190 T:427 INFO <general>: Local hostname: osmc
2021-08-19 13:32:58.190 T:427 INFO <general>: Log File is located: /home/osmc/.kodi/temp/kodi.log
2021-08-19 13:32:58.190 T:427 INFO <general>: -----------------------------------------------------------------------
2021-08-19 13:32:58.204 T:427 INFO <general>: loading settings
2021-08-19 13:32:58.207 T:427 INFO <general>: special://profile/ is mapped to: special://masterprofile/
2021-08-19 13:32:58.249 T:427 INFO <general>: Loaded settings file from special://xbmc/system/advancedsettings.xml
2021-08-19 13:32:59.480 T:427 INFO <general>: Selected Logind/UPower as PowerSyscall
2021-08-19 13:32:59.480 T:427 ERROR <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2021-08-19 13:32:59.481 T:427 INFO <general>: LogindUPowerSyscall - UPower not found, battery information will not be available
2021-08-19 13:32:59.599 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device default description
2021-08-19 13:32:59.655 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device sysdefault:CARD=vc4hdmi description vc4-hdmi, MAI PCM vc4-hdmi-hifi-0
Default Audio Device
2021-08-19 13:32:59.657 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=vc4hdmi,DEV=0 description vc4-hdmi, MAI PCM vc4-hdmi-hifi-0
HDMI Audio Output
2021-08-19 13:32:59.672 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device sysdefault:CARD=Device description USB PnP Sound Device, USB Audio
2021-08-19 13:32:59.679 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device @:CARD=Device,DEV=0 description USB PnP Sound Device, USB Audio
Front speakers
2021-08-19 13:32:59.685 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device surround21:CARD=Device,DEV=0 description USB PnP Sound Device, USB Audio
2.1 Surround output to Front and Subwoofer speakers
2021-08-19 13:32:59.685 T:496 INFO <general>: CAESinkALSA - No playback configurations available for device "surround21:CARD=Device,DEV=0"
2021-08-19 13:32:59.686 T:496 INFO <general>: CAESinkALSA::EnumerateDevice - device iec958:CARD=Device,DEV=0 description USB PnP Sound Device, USB Audio
IEC958 (S/PDIF) Digital Audio Output
2021-08-19 13:32:59.687 T:496 INFO <general>: Found 1 Lists of Devices
2021-08-19 13:32:59.687 T:496 INFO <general>: Enumerated ALSA devices:
2021-08-19 13:32:59.687 T:496 INFO <general>: Device 1
2021-08-19 13:32:59.687 T:496 INFO <general>: m_deviceName : default
2021-08-19 13:32:59.687 T:496 INFO <general>: m_displayName : Default (vc4-hdmi MAI PCM vc4-hdmi-hifi-0)
2021-08-19 13:32:59.687 T:496 INFO <general>: m_displayNameExtra:
2021-08-19 13:32:59.687 T:496 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2021-08-19 13:32:59.687 T:496 INFO <general>: m_channels : FL, FR
2021-08-19 13:32:59.687 T:496 INFO <general>: m_sampleRates : 32000,44100,48000
2021-08-19 13:32:59.687 T:496 INFO <general>: m_dataFormats : AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
2021-08-19 13:32:59.687 T:496 INFO <general>: m_streamTypes : No passthrough capabilities
2021-08-19 13:32:59.687 T:496 INFO <general>: Device 2
2021-08-19 13:32:59.687 T:496 INFO <general>: m_deviceName : sysdefault:CARD=vc4hdmi
2021-08-19 13:32:59.687 T:496 INFO <general>: m_displayName : vc4-hdmi
2021-08-19 13:32:59.687 T:496 INFO <general>: m_displayNameExtra: MAI PCM vc4-hdmi-hifi-0
2021-08-19 13:32:59.688 T:496 INFO <general>: m_sampleRates : 32000,44100,48000
2021-08-19 13:32:59.688 T:496 INFO <general>: m_dataFormats : AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
2021-08-19 13:32:59.688 T:496 INFO <general>: m_streamTypes : No passthrough capabilities
2021-08-19 13:32:59.688 T:496 INFO <general>: Device 3
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceName : hdmi:CARD=vc4hdmi,DEV=0
2021-08-19 13:32:59.688 T:496 INFO <general>: m_displayName : vc4-hdmi
2021-08-19 13:32:59.688 T:496 INFO <general>: m_displayNameExtra: SAM SAMSUNG on HDMI
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceType : AE_DEVTYPE_HDMI
2021-08-19 13:32:59.688 T:496 INFO <general>: m_channels : FL, FR
2021-08-19 13:32:59.688 T:496 INFO <general>: m_dataFormats : AE_FMT_RAW,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8,AE_FMT_RAW
2021-08-19 13:32:59.688 T:496 INFO <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2021-08-19 13:32:59.688 T:496 INFO <general>: Device 4
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceName : @:CARD=Device,DEV=0
2021-08-19 13:32:59.688 T:496 INFO <general>: m_displayName : USB PnP Sound Device
2021-08-19 13:32:59.688 T:496 INFO <general>: m_displayNameExtra: Analog
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2021-08-19 13:32:59.688 T:496 INFO <general>: m_sampleRates : 48000
2021-08-19 13:32:59.688 T:496 INFO <general>: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
2021-08-19 13:32:59.688 T:496 INFO <general>: Device 5
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceName : iec958:CARD=Device,DEV=0
2021-08-19 13:32:59.688 T:496 INFO <general>: m_displayNameExtra: S/PDIF
2021-08-19 13:32:59.688 T:496 INFO <general>: m_deviceType : AE_DEVTYPE_IEC958
2021-08-19 13:32:59.688 T:496 INFO <general>: m_sampleRates : 44100,48000
2021-08-19 13:32:59.688 T:496 INFO <general>: m_dataFormats : AE_FMT_RAW,AE_FMT_S16NE,AE_FMT_S16LE
2021-08-19 13:32:59.688 T:496 INFO <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
2021-08-19 13:32:59.689 T:497 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-19 13:32:59.689 T:497 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "iec958:CARD=Device,DEV=0"
2021-08-19 13:32:59.700 T:497 INFO <general>: CAESinkALSA::Initialize - Opened device "iec958:CARD=Device,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2021-08-19 13:32:59.702 T:497 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-08-19 13:32:59.702 T:497 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2
2021-08-19 13:33:15.311 T:530 INFO <general>: Register - new cec device registered on cec->Linux: CEC Adapter (0000:0000)
2021-08-19 13:33:44.964 T:427 INFO <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2021-08-19 13:33:47.881 T:427 INFO <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
2021-08-19 13:33:54.147 T:427 INFO <general>: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
2021-08-19 13:33:56.575 T:497 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-19 13:33:56.576 T:497 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "@:CARD=Device,DEV=0"
2021-08-19 13:33:56.591 T:497 INFO <general>: CAESinkALSA::Initialize - Opened device "sysdefault:CARD=Device"
2021-08-19 13:33:56.593 T:497 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-08-19 13:33:56.593 T:497 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-08-19 13:34:02.611 T:497 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-19 13:34:02.613 T:497 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2021-08-19 13:34:02.631 T:497 INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2021-08-19 13:34:02.634 T:497 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-08-19 13:34:02.635 T:497 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE3
2021-08-19 13:34:17.494 T:497 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-19 13:34:17.495 T:497 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "@:CARD=Device,DEV=0"
2021-08-19 13:34:17.520 T:497 INFO <general>: CAESinkALSA::Initialize - Opened device "sysdefault:CARD=Device"
2021-08-19 13:34:17.523 T:497 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2021-08-19 13:34:17.523 T:497 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2021-08-19 13:34:18.697 T:427 WARNING <general>: CGUIWindowManager - HandleAction - ignoring action 7, because topmost modal dialog closing animation is running
2021-08-19 13:34:59.937 T:536 INFO <general>: ES: Client from ::ffff:192.168.1.216 timed out
2021-08-19 13:35:21.960 T:536 INFO <general>: ES: Client from ::ffff:192.168.1.216 timed out
What is your sound card chip?
Thank you
