I have been having a problem with osmc. This is a topic I have seen a bit on the forums. the thing that happening is that osmc does not show up on my monitor I just get a no signal and it goes on to standby but the on light on the pi is on. I have tried HDMI Hotplug. but it does not work. I am using a Raspberry Pi2 and my monitor is VGA only; for this i use a HDMI to VGA adapter, Could this be the problem?
So you are talking about first boot of the installer I assume?
Really nothing on the screen at all?
Have you tried other OS like Raspbian?
After you try to boot can you check the SD card in a PC? Is there an install log on the boot partition, what does it say?
I have a problem same as Dubbed wz osmc. My Pi3 is happening that osmc does not show up on my monitor on my car and my TV. I have to format and reinstall osmc again 2nd times. It really make me tied.
No I can boot up and install fine bit after i shutdown my pi it wont boot again. There is nothing on the screen at all. I have tried to install kodi on rasbian but with no success. I will post the boot logs when I find them
Install logs are as follows (note that i have reinstalled osmc) –
Thu Jan 1 00:00:08 1970 Starting OSMC installer
Thu Jan 1 00:00:17 1970 Detecting device we are running on
Thu Jan 1 00:00:17 1970 Mounting boot filesystem
Thu Jan 1 00:00:17 1970 Trying to mount to MNT_BOOT (/mnt/boot)
Thu Jan 1 00:00:17 1970 Using device->boot: /dev/mmcblk0p1 and FS: fat32
Thu Jan 1 00:00:17 1970 Preseed file found, will attempt to parse
Thu Jan 1 00:00:17 1970 Found a definition for storage: sd
Thu Jan 1 00:00:17 1970 Creating root partition
Thu Jan 1 00:00:17 1970 From a root partition of /dev/mmcblk0p2, I have deduced a base device of /dev/mmcblk0
Thu Jan 1 00:00:17 1970 Determined 255 MB as end of first partition
Thu Jan 1 00:00:17 1970 Calling mkpart for device: /dev/mmcblk0 and fs: ext4 with start 257M and end 100%
Thu Jan 1 00:00:19 1970 Calling fmtpart for partition /dev/mmcblk0p2 and fstype ext4
Thu Jan 1 00:00:32 1970 Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=2 blocks, Stripe width=1024 blocks
962880 inodes, 3850752 blocks
192537 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=3946840064
118 block groups
32768 blocks per group, 32768 fragments per group
8160 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
