Hey people, can’t figure out why my RPi is not booting/installing/loading (don’t know what you call this) the OSMC.
(1) I first installed OSMC onto my SD card (16gb) using the Web Installed that osmc.tv provides, it didn’t worked.
(2) After that, i formatted my SD card and directly installed OSMC disk image using Win32DiskImager, and it behaved the same.
Now i wanna tell you, where it gets stuck (check out the Screenshot)
It does not respond anyway, and i’m installing the latest OSMC version but response is same in both the cases [web installer(1) and direct disk imager (2)]
Let me tell you, it works fine with Raspbian (installed using NOOBS) and other OSes.
Do you mean it didn’t work to put the image on the SD card at all or you mean installation got stuck after you put the SD card into the Pi (like your picture shows?
I mean the installation gets stuck after i put the sd card into the pi, just as the screenshot shows.
And by (1) Web installer, i meant the installer that osmc.tv provides (which on demand installs osmc in the card by downloading the software from the internet). And by (2) direct Disk Image installation, i downloaded and installed Disk Image using Win32DiskImager.
But in both cases (1) and (2), the installation gets stuck after i put the sd card into the Pi.
By the way, i’m installing this version :
Raspberry Pi 2 / 3
Release Checksum (MD5)
2016.09-1 c3605fac9baeabb812d4147ae733c6c7
I’d try another power supply first. Failing that another SD card. If it’s a new SD also test that its not fake by using H2testw. (You might only have a 4GB card but sold as a 16GB)
Getting enough power to the Pi3 has been a bitch. Another problem I had earlier this year was WinZip not correctly decompressing images that passed checksum. 7_Zip does.
I maybe just talking old thing, but my problem was that after installed from an image when i did a few updates usually 2 or 3 after restart the system always died. Util i have replaced the 16Gb SDcard with an 8 Gb SDcard and never had the problem again.
ps: the 16Gb SDCard still in use in other devices so it wasn’t the case of (4Gb SDCard sold as 16GB). It’s just somehow during the update the partition has been corrupted.
But as i said may be this is an old thing, and the problem already fixed.
