Oops, sorryā¦itās a Pi 1. Too much moving between systems with 3 Pi 1s and 2 Pi 2s.
Your problem is that your rbp1-mediacenter-osmc package (Kodi) has not updated, it should be 15.2.0-8 but yours is 15.2.0-1 which is from October 28th.
I canāt see anything from your logs why this has not updated, so I can only assume you have used apt-mark to hold the package ?
This means you are an old version of Kodi.
Please post dpkg -l | grep mediacenter-osmc
Try checking for updates again using the official mechanism, the OSMC Updater: via My OSMC ā Updater. Please let us know if the issue persists, and if it does, the output of dpkg -l | grep mediacenter-osmc
Just a note, that I ended up in the situation (HDMI-CEC not working) using the OSMC updater via My OSMC -> Updater.
The output on the systems shows.
osmc@osmc:~$ dpkg -l | grep mediacenter-osmc
ii rbp1-mediacenter-osmc 15.2.0-1 armhf Media Center package for OSMC
osmc@osmc:~$
so, is there a problem with the updater?
I tried running the upgrade again. It is now stating that there is no update available.
Jens
Didnāt use apt-mark. I did a regular upgrade when alerted of the November update and was prompted if I wanted to update. Following the update I identified the CEC problem. I did a sudo apt-get update; sudo systemctl start manual-update to force another update. That is the current state of the system.
Hang onā¦
I have rpi1, i do this: sudo apt-get update, sudo apt-get dist-upgrade, sudo reboot,
but:
and CEC dont work
Additionally, I did:
sudo apt-get update
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
Calculating upgrade⦠Done
Didnāt bother to rebootā¦no packages needed upgrading.
Do it one more time chaps, I suspect it will work nowā¦
Hmm.
Well, I installed the system (October release) with the OSMC installer yesterday, and used the official My OSMC update procedure today - which broke it.
I executed the recommended commands. No upgrades were done, but the I got "
Calculating upgrade⦠The following package was automatically installed and is no longer required:
rbp1-image-4.2.3-3-osmc
Use āapt-get autoremoveā to remove it."
I did not do this. After the reboot, I tried again:
osmc@osmc:~$
So, no changeā¦
Hmm
Jens
I can confirm my kodi was out of date, but the update the same way I have always done:
My osmc
updates
Manuel controls
scan for updates.
Just done it again, showing no updates. Do you recommend I remove the symlinks I created and run the sudo apt-get commands.
Thanks Tom.
Iāve tried doing update via ssh too, still no joy
Please cat /etc/apt/sources.list
I have tested on an affected user via SSH moments ago and an update && dist-upgrade did resolve the issue.
osmc@osmc:~$ cat /etc/apt/sources.list
deb Index of /raspbian jessie main contrib non-free
deb http://staging.apt.osmc.tv jessie main
osmc@osmc:~$
If the issue still persists, you have a transparent proxy causing caching by your ISP. Change staging.apt.osmc.tv to apt.osmc.tv and re-run
root@OSMC-TV:~# cat /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian jessie main contrib non-free
root@OSMC-TV:~#
Me being a new poster and having now posted three items on this topic I wonāt be able to add additional posts until someone changes my status.
Hi Sam,
osmc@OSMC-Bedroom:~$ cat /etc/apt/sources.list
deb http://apt.osmc.tv jessie main
still not working ![]()
Guys, you are all trying :-
