I have osmc and a couple of other things (tvheadend, minidlna) running on a pi 3b+ which has been working fine for ages.
After a reboot, I got the sad face and it seems mediacenter is segfaulting.
Jan 25 21:44:07 raspiii mediacenter[550]: Mesa warning: failed to remap glInternalBufferSubDataCopyMESA
Jan 25 21:44:09 raspiii sudo[884]: pam_unix(sudo:session): session closed for user osmc
Jan 25 21:44:09 raspiii mediacenter[550]: /usr/bin/mediacenter: line 142: 884 Segmentation fault sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Jan 25 21:44:09 raspiii mediacenter[550]: Kodi exited with return code 139 after 0 hours, 0 minutes and 5 seconds
All apt packages are up-to-date.
I’ve tried with most of the USB devices (external storage / TV receiver) unplugged and I’ve also tried moving my ~/.kodi directory, but none of these seem to have made much difference.
Thanks in advance for any help (and for OSMC, which I’ve been using for quite a while!)
Yeah, I’ve noticed the under-voltage messages. I think they mostly stop once the system is booted, and I doubt they’d cause a segfault, but I don’t know for sure what is causing it so… yes. Maybe.
FWIW I managed to get a core dump from kodi and had a look at it with gdb:
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x75fd198c in sc_reduce () from /usr/osmc/lib/libshairplay.so.0
[Current thread is 1 (Thread 0x722b3040 (LWP 21976))]
(gdb) bt
#0 0x75fd198c in sc_reduce () at /usr/osmc/lib/libshairplay.so.0
#1 0x08d7e05c in ()
I’m not sure how useful that is.
I’ve also run kodi through strace, and noted that we see a log message saying the webserver has started on port 80, a syscall reading from /dev/urandom and then the segfault happens.
I still get under voltage with all of the peripherals plugged in, but it seems only during boot. Afterwards, everything else seems to work fine (tvheadend, minidlna, and I see no problems when ssh’ed in).
To eliminate the under voltage as a cause, I’ve booted with nothing plugged into USB.
No under voltage this time, but still the same mediacenter segmentation fault and sad face loop.
No under-voltage but mediacenter is still segfaulting.
~$ systemctl status mediacenter | tail -n4
Jan 27 11:40:23 raspiii mediacenter[502]: Mesa warning: failed to remap glInternalBufferSubDataCopyMESA
Jan 27 11:40:25 raspiii sudo[1550]: pam_unix(sudo:session): session closed for user osmc
Jan 27 11:40:25 raspiii mediacenter[502]: /usr/bin/mediacenter: line 142: 1550 Segmentation fault sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Jan 27 11:40:25 raspiii mediacenter[502]: Kodi exited with return code 139 after 0 hours, 0 minutes and 4 seconds
I might try and replace the relevant binaries from a clean install etc… but otherwise will try a new install of osmc and then set everything up again on top of it.
If your original SD hard had corruption caused by under-voltage then DDing it to a new card will also copy the corrupted files. I’d suggest a fresh install on the new SD card.
