I have not used my Pi for a few days, I know an update for OSMC was pushed at the weekend as I can remember updating. However since the update OSMC will not load and is just stuck on the OSMC Splash screen.
I can still SSH into the Pi and logs below. Any advice would be appreciated to save me having to reformat ! (however Im a noob with linux command line) so please be friendly with commands
I have also tried df-h and have plenty available space on SD Card. Simple reboot commands from putty and still stuck.
Nothing obvious from your log files unfortuantely. The APT logs look fine and so does the journal. A Kodi log would have been nice to see…
You don’t use a MySQL install by any chance ? The journal shows Kodi is launching and is not crashing, that could be consistent with a MySQL install that is unable to connect to it’s server.
No sign of Kodi crashing in your logs. What sort of TV do you have connected and what resolution can it go up to ? The following command will report the current resolution:
tvservice -s
The following commands will report the modes that your TV advertises it supports:
LG TV. Full HD 1080p worked no probs until this week.
None of the tvservice commands you provided return any information via SSH. Putty just seems to stop and not return any data and does not return me back to a command line for any further input ?
just did update via my osmc, it came up in desktop (640x480, started in 1080p)
so in settings>system>video, i set 1080p, got blackscreen:-\
bounced kodi from cli, screen came back but unresponsive to mouse/kbd:-
rebooting now…came up in 640x480
lather rinse repeat
but now responsive (killed osmc’s kodi, not root’s)
system>video still says desktop resolution, but severely overscanned
video calibration can adjust the upper left corner, but not lower right:-
bounced kodi again, this time adjusted l-r 1st, hal-lay-loo-ya!-}
h/w acceleration essential, still waiting for the key
and exiting live tv kills the picture, but the sound carries on & holds the tuner
waf = 0
