OSMC on Pi2 can read attached DoK but cannot write to it
OSMC on Pi2 can read attached DoK but cannot write to it. Any ideas anyone?
And that is ?
Sorry, DoK = Disk on Key
What file system is it formatted with ? HFS+ is only supported as read only at the moment.
Definitely not HFS+. It’s either NTFS, FAT32, xFat or Fat. I used it before with same Pi2 and OpenElec installed and OpenElec could both read and write to it.
Provide dmesg output after you plugged it in.
As well as fdisk -l and mount output
I assume you’re asking me to go to command line in linux?
Details regarding how to access the command line interface can be found here on our Wiki: Accessing the command line - General - OSMC
