When I install OSMC using NOOBS, it doesn’t work. However when I do a clean install, it does. I want to be able to use OSMC on NOOBS. Does anyone know how?
Issue: When I start it up, it shows a console. Then it shows another console saying that one of the filesystems is corrupted. It tries again and I get this: FATAL ERROR: OSMC cannot mount /dev/mmcblk0p2 of ext4 filesystem. Then, I end up being able to type commands.
What I was doing: I installed OSMC along with Risc OS and Windows Iot Core on NOOBS.
How to replicate: I booted up my Raspberry Pi to the NOOBS OS selector screen. I open OSMC and a minute later, I get the error.
Device: Raspberry Pi w/ NOOBS
Device attachments: Only a wifi adapter, ethernet cable, wireless mouse and keyboard adapter, HDMI, and a power source.
Presence: It only happens with NOOBS. The clean install works perfectly. Please don’t say to use the clean install unless there isn’t a choice.
Logs: There aren’t any logs to upload. The emergency command line won’t let me upload logs.
Well hard to say as many factors can play a role in your NOOBS setup.
The only thing that I can say is that most of us had best results with SanDisk or Samsung SD cards.
