OSMC rasbery pi3 1g buffering. Some movies or series is impossible to watch as it starts to be seen and then stops.
the movie or series starts but stops and the time indicator stops and goes back and advances but not continuous. What can be done with a single 1g of memory I do not think it’s a buffer problem
HI,
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
- publish the provided URL from the log set upload, here
Thanks Tom.
It would be good if we could find out more about the file you are having issues playing. Please see the mediainfo section in How to submit a useful support request - General - OSMC.
You can also create the mediainfo
-output of the affected media file on the OSMC device:
- login via SSH, user
osmc
, passwordosmc
- if not already installed:
sudo apt-get update && sudo apt-get install mediainfo
cd
to the directory containing the video/audio material in questionmediainfo -f "<media file>"|paste-log
, where<media file>
is your video/audio- publish the returned URL here in this topic
Thx for your help.
