Hello, I am planning to buy Technisat USB HD DVB-S .
My first question is,
Does this work on raspberry Pi2 + OSMC ?
If yes, Can I configure biss keys and cccam ?
Do you have any instructions to do this?
Thanks in advance…
Thanks in advance…
Here’s list of compatible dvb-s2 tuners
https://www.linuxtv.org/wiki/index.php/DVB-S2_USB_Devices
Technisat skystar HD is on there so should work. You will prob have to download firmware if its isn’t included in osmc and place it in /lib/firmware.
Free to air channels work not sure about keys and ccam.
Good luck
To watch encrypted channels you can use oscam and connect it to tvheadend via dvbapi.
I have a similar setup but with cccam only and it works very well.
