I have an OSMC installation on a Raspberry Pi 3 and it was working well. I bought a 3 B+ and swapped the sd card and now it won’t boot. The installation was up to date before doing the swap. Any idea on how to solve this without reinstalling? I had several applications running on different ports, etc, and I would not want to start from scratch.
I’m attaching here a couple of screenshots. One is from the rpi3b+ and the other one from the rpi3. None of them boot at the moment. I created the logs but when I insert the SD card in a computer I can’t see all the contents. I see a bunch of files but I don’t see a boot or home folders so I can not transfer the logs back to the computer in order to upload them. Besides that, the networking on both raspberry is not working.
If it’s a Windows machine, you’ll only be able to see the /boot partition and files. Th ext4 partition which holds the vast majority of files/folders will not be visible.
Derek
As already noted, the network is unreachable from your Pi 3B+. This is likely a result of you having installed pihole, which has caused dhcpcd5 to be installed.
You probably need to remove the dhcpcd5 package in order to get network connectivity back. Unfortunately, unless you can attach a keyboard and get to the command line, things might be a bit tricky. AFAIK, the default systemd timeout is 90 seconds, so a bit of patience might be in order during the startup, since quite a few services will expect network access.
If you can eventually get to the command line, run this:
Well, I uninstalled dhcpcd5, setup connman to use dhcp on that interface (I was using static ip anyway), configured my router to assign the ip automatically to that mac address, did apt update, dist-upgrade, etc, and so far so good. I have recovered all my applications and they seem to be running as expected.
