Whenever I try to play drm restricted content with SlyGuys Paramount+ addon, OSMC crashes. Playing trailers on Paramount+ works.
I have version 4.10.2662.3 of Widevine CDM installed.
There’s really not much anyone can do if you don’t post some debug logs showing the crash.
that is the end of Kodi Old Log
2025-01-08 01:45:12.580 T:664 info <general>: slyguy.paramount.plus - Widevine - System: Linux | Arch: armv7
2025-01-08 01:45:12.856 T:664 info <general>: slyguy.paramount.plus - Widevine Current MD5: 9aff9fa1f4d1b97532a6f5c8ef2cc914
2025-01-08 01:45:12.888 T:484 info <general>: VideoPlayer::OpenFile: plugin://slyguy.paramount.plus/?_=play&_play=1&profile_id=*
2025-01-08 01:45:12.894 T:711 info <general>: Creating InputStream
2025-01-08 01:45:13.005 T:711 warning <general>: AddOnLog: inputstream.adaptive: Warning "inputstream.adaptive.manifest_type" property is deprecated and will be removed next Kodi version, the manifest type is now automatically detected.
If you are using a proxy remember to add the appropriate "content-type" header to the HTTP manifest response
See Wiki page "How to provide custom manifest/license" to learn more about it.
2025-01-08 01:45:13.008 T:711 info <general>: AddOnLog: inputstream.adaptive: [Repr. chooser] Resolution set: 1280x720, max allowed: 1920x1080, Adjust refresh rate: 1
2025-01-08 01:45:21.223 T:711 warning <general>: AddOnLog: inputstream.adaptive: ParseTagRepresentation: Cannot get codecs for representation with id: "thumb_160x90". Representation skipped.
2025-01-08 01:45:21.224 T:711 warning <general>: AddOnLog: inputstream.adaptive: ParseTagRepresentation: Cannot get codecs for representation with id: "thumb_320x180". Representation skipped.
2025-01-08 01:45:21.224 T:711 warning <general>: AddOnLog: inputstream.adaptive: ParseTagAdaptationSet: Skipped AdaptationSet with id: "10", has no representations.
2025-01-08 01:45:21.224 T:711 info <general>: AddOnLog: inputstream.adaptive: Manifest successfully parsed (Periods: 1, Streams in first period: 10, Type: VOD)
and this the system journal before the crash
Jan 08 01:45:21 osmc mediacenter[484]: Mesa: error: 1 similar GL_INVALID_VALUE errors
Jan 08 01:45:21 osmc mediacenter[484]: Mesa: error: GL_INVALID_VALUE in glDisableVertexAttribArray(index)
Jan 08 01:45:21 osmc sudo[474]: pam_unix(sudo:session): session closed for user osmc
Jan 08 01:45:21 osmc mediacenter[407]: /usr/bin/mediacenter: line 149: 474 Segmentation fault sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Jan 08 01:45:21 osmc mediacenter[407]: Kodi exited with return code 139 after 0 hours, 2 minutes and 4 seconds
Please post some full logs.
Any ideas? I tested the same on a Fedora install on the Pi and with the Kodi Flatpak and it worked without issue
Did you check if the Widevine CDM versions were the same?
yes they are the same version
