I’m considering the purchase of a Raspberry Pi as a way to seamlessly push music via Airplay. I see that OSMC supports Airplay in the ways that I would want it to (I don’t need mirroring), but my question is about the need for continued setup, or lack there off.
Feature I’m trying to emulate:
With an Airport Express (AE), once it’s setup, you can unplug it and plug it back in all over the place, with no need to interact with it. If you push music from a computer to multiple AE devices via airplay, it just starts playing.
Question:
Can OSMC + Raspberry Pi be setup in a similar way, such that interaction with the device is not required once it is initially setup? Put a different way, can it be setup such that unpluggin the device and moving it to a different room will not require user interaction?
I apologize if greater knowledge of the Raspberry Pi product and ecosystem would allow me to recognize that I just asked a stupid question. I’m absorbing as much as I can as fast as I can, but figured a direction question would give me just enough info to make the purchase decision, and then I can take it from there
Thanks!
