… and I say that it doesn’t start, because it boots perfectly.
Let me explain,
I have dual boot from noobs, raspbian is Ok, but OSMC doesn’t start.
I bought Raspberry 3 about 2 months ago, it worked flawless till last night, when I tried to start it and I got the sad smile.
It would be easy to reinstall it, but I don’t have spare time to make it as I want to, with all the repos and addons.
My log file:
21:39:00 9.813756 T:1956819888 NOTICE: special://profile/ is mapped to: special://masterprofile/ 21:39:00 9.813892 T:1956819888 NOTICE: ----------------------------------------------------------------------- 21:39:00 9.813939 T:1956819888 NOTICE: Starting Kodi (16.1). Platform: Linux ARM (Thumb) 32-bit 21:39:00 9.813973 T:1956819888 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi) 21:39:00 9.814010 T:1956819888 NOTICE: Kodi compiled May 3 2016 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711) 21:39:00 9.814275 T:1956819888 NOTICE: Running on Open Source Media Center 2016.05-1, kernel: Linux ARM 32-bit version 4.4.8-3-osmc 21:39:00 9.814317 T:1956819888 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0 21:39:00 9.814390 T:1956819888 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available 21:39:00 9.814419 T:1956819888 NOTICE: ARM Features: Neon disabled 21:39:00 9.814450 T:1956819888 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 21:39:00 9.814498 T:1956819888 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi 21:39:00 9.814528 T:1956819888 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata 21:39:00 9.814558 T:1956819888 NOTICE: special://home/ is mapped to: /home/osmc/.kodi 21:39:00 9.814588 T:1956819888 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp 21:39:00 9.814653 T:1956819888 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin 21:39:00 9.814726 T:1956819888 NOTICE: Local hostname: osmc 21:39:00 9.814760 T:1956819888 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log 21:39:00 9.814805 T:1956819888 NOTICE: ----------------------------------------------------------------------- 21:39:00 10.077204 T:1956819888 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files 21:39:00 10.092127 T:1956819888 NOTICE: load settings... 21:39:00 10.269753 T:1956819888 NOTICE: Found 2 Lists of Devices 21:39:00 10.269860 T:1956819888 NOTICE: Enumerated PI devices: 21:39:00 10.269893 T:1956819888 NOTICE: Device 1 21:39:00 10.270430 T:1956819888 NOTICE: m_deviceName : HDMI 21:39:00 10.270487 T:1956819888 NOTICE: m_displayName : HDMI 21:39:00 10.270518 T:1956819888 NOTICE: m_displayNameExtra: 21:39:00 10.270565 T:1956819888 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 21:39:00 10.270595 T:1956819888 NOTICE: m_channels : FL,FR 21:39:00 10.270627 T:1956819888 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000 21:39:00 10.270659 T:1956819888 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3 21:39:00 10.270781 T:1956819888 NOTICE: Device 2 21:39:00 10.270842 T:1956819888 NOTICE: m_deviceName : Analogue 21:39:00 10.270873 T:1956819888 NOTICE: m_displayName : Analogue 21:39:00 10.270903 T:1956819888 NOTICE: m_displayNameExtra: 21:39:00 10.270933 T:1956819888 NOTICE: m_deviceType : AE_DEVTYPE_PCM 21:39:00 10.270962 T:1956819888 NOTICE: m_channels : FL,FR 21:39:00 10.270991 T:1956819888 NOTICE: m_sampleRates : 48000 21:39:00 10.271023 T:1956819888 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP 21:39:00 10.271053 T:1956819888 NOTICE: Device 3 21:39:00 10.271108 T:1956819888 NOTICE: m_deviceName : Both 21:39:00 10.271138 T:1956819888 NOTICE: m_displayName : HDMI and Analogue 21:39:00 10.271168 T:1956819888 NOTICE: m_displayNameExtra: 21:39:00 10.271196 T:1956819888 NOTICE: m_deviceType : AE_DEVTYPE_PCM 21:39:00 10.271226 T:1956819888 NOTICE: m_channels : FL,FR 21:39:00 10.271255 T:1956819888 NOTICE: m_sampleRates : 48000 21:39:00 10.271411 T:1956819888 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP 21:39:00 10.271446 T:1956819888 NOTICE: Enumerated ALSA devices: 21:39:00 10.271475 T:1956819888 NOTICE: Device 1 21:39:00 10.271553 T:1956819888 NOTICE: m_deviceName : default 21:39:00 10.271585 T:1956819888 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA) 21:39:00 10.271615 T:1956819888 NOTICE: m_displayNameExtra: 21:39:00 10.271644 T:1956819888 NOTICE: m_deviceType : AE_DEVTYPE_PCM 21:39:00 10.271674 T:1956819888 NOTICE: m_channels : FL,FR,LFE,UNKNOWN1,FC,BL,BR,BC,BLOC,BROC,FLOC,FROC,TFC,TC,TFL,TFR 21:39:00 10.271705 T:1956819888 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000 21:39:00 10.271734 T:1956819888 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8 21:39:00 10.287370 T:1956819888 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml 21:39:00 10.287698 T:1956819888 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are... <?xml version="1.0" encoding="UTF-8" ?> <!-- Do not modify! These are OSMC Optimised Settings for your device !--> <!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !--> <!-- It will override these settings, and your settings will be preserved across OSMC updates !--> <advancedsettings> <network> <readbufferfactor>4.0</readbufferfactor> </network> <imageres>540</imageres> <fanartres>720</fanartres> <splash>false</splash> <handlemounting>0</handlemounting> <samba> <clienttimeout>30</clienttimeout> </samba> </advancedsettings> 21:39:00 10.289237 T:1956819888 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 21:39:00 10.289300 T:1956819888 NOTICE: Default DVD Player: dvdplayer 21:39:00 10.289330 T:1956819888 NOTICE: Default Video Player: dvdplayer 21:39:00 10.289493 T:1956819888 NOTICE: Default Audio Player: paplayer 21:39:00 10.289544 T:1956819888 NOTICE: Disabled debug logging due to GUI setting. Level 0. 21:39:00 10.289577 T:1956819888 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 21:39:00 10.289769 T:1956819888 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml 21:39:00 10.292270 T:1956819888 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 21:39:00 10.293927 T:1956819888 NOTICE: Loaded playercorefactory configuration 21:39:00 10.294257 T:1956819888 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 21:39:00 10.294436 T:1956819888 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 21:39:00 10.303735 T:1956819888 NOTICE: WakeOnAccess - Load settings : 21:39:00 10.303834 T:1956819888 NOTICE: WakeOnAccess - Enabled:FALSE 21:39:00 10.303869 T:1956819888 NOTICE: -Network init timeout : [20] sec 21:39:00 10.303902 T:1956819888 NOTICE: -Network settle time : [500] ms 21:39:00 10.303947 T:1956819888 NOTICE: Registering wakeup entry: 21:39:00 10.303977 T:1956819888 NOTICE: HostName : MINT-PC 21:39:00 10.304034 T:1956819888 NOTICE: MacAddress : D8:5D:4C:96:0A:3F 21:39:00 10.304065 T:1956819888 NOTICE: PingPort : 0 21:39:00 10.304093 T:1956819888 NOTICE: PingMode : 0 21:39:00 10.304265 T:1956819888 NOTICE: Timeout : 300 (sec) 21:39:00 10.304299 T:1956819888 NOTICE: WaitForOnline : 40 (sec) 21:39:00 10.304470 T:1956819888 NOTICE: WaitForOnlineEx : 40 (sec) 21:39:00 10.304499 T:1956819888 NOTICE: WaitForServices : 5 (sec) 21:39:01 10.880322 T:1956819888 NOTICE: Running database version Addons20 21:39:02 11.966677 T:1956819888 NOTICE: ADDONS: Using repository repository.tknorris.beta 21:39:02 11.966778 T:1956819888 NOTICE: ADDONS: Using repository repository.exodus 21:39:02 11.966810 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.video 21:39:02 11.966840 T:1956819888 NOTICE: ADDONS: Using repository repository.catoal 21:39:02 11.966869 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.comedy 21:39:02 11.966899 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.repositories 21:39:02 11.966929 T:1956819888 NOTICE: ADDONS: Using repository repository.HalowTV 21:39:02 11.966959 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.live-tv 21:39:02 11.966989 T:1956819888 NOTICE: ADDONS: Using repository repository.bbtsip.tv 21:39:02 11.967018 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.movies 21:39:02 11.967048 T:1956819888 NOTICE: ADDONS: Using repository repository.ororotv 21:39:02 11.967076 T:1956819888 NOTICE: ADDONS: Using repository repository.aresproject 21:39:02 11.967106 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.sports 21:39:02 11.967135 T:1956819888 NOTICE: ADDONS: Using repository repository.spoyser 21:39:02 11.967165 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.movies 21:39:02 11.967194 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.tv-shows 21:39:02 11.967223 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.music 21:39:02 11.967253 T:1956819888 NOTICE: ADDONS: Using repository repository.filmkodi.com 21:39:02 11.967282 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.external.repositories 21:39:02 11.967311 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.kids 21:39:02 11.967340 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.subtitles 21:39:02 11.967370 T:1956819888 NOTICE: ADDONS: Using repository repository.popcornmix 21:39:02 11.967400 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.external.repositories 21:39:02 11.967428 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.repositories 21:39:02 11.967458 T:1956819888 NOTICE: ADDONS: Using repository repo.natko1412 21:39:02 11.967487 T:1956819888 NOTICE: ADDONS: Using repository repository.OperationRobocop 21:39:02 11.967516 T:1956819888 NOTICE: ADDONS: Using repository repository.featherence 21:39:02 11.967546 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.live-tv 21:39:02 11.967574 T:1956819888 NOTICE: ADDONS: Using repository repository.podgod 21:39:02 11.967604 T:1956819888 NOTICE: ADDONS: Using repository repository.q 21:39:02 11.967633 T:1956819888 NOTICE: ADDONS: Using repository repository.kodipopcorntime 21:39:02 11.967662 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.comedy 21:39:02 11.967691 T:1956819888 NOTICE: ADDONS: Using repository repository.eldorado 21:39:02 11.967719 T:1956819888 NOTICE: ADDONS: Using repository repository.xbmchub 21:39:02 11.967749 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.comics 21:39:02 11.967779 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.tv-shows 21:39:02 11.967808 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.news-and-weather 21:39:02 11.967837 T:1956819888 NOTICE: ADDONS: Using repository xbmc.repo.elmerohueso 21:39:02 11.967894 T:1956819888 NOTICE: ADDONS: Using repository repository.mdrepo 21:39:02 11.967923 T:1956819888 NOTICE: ADDONS: Using repository repository.tva.common 21:39:02 11.967952 T:1956819888 NOTICE: ADDONS: Using repository repository.xbmc.org 21:39:02 11.967980 T:1956819888 NOTICE: ADDONS: Using repository repository.aeon.nox.silvo 21:39:02 11.968009 T:1956819888 NOTICE: ADDONS: Using repository repository.lambda 21:39:02 11.968038 T:1956819888 NOTICE: ADDONS: Using repository repository.communityrepo 21:39:02 11.968067 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.helix.subtitles 21:39:02 11.968096 T:1956819888 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.video 21:39:02 11.968124 T:1956819888 NOTICE: ADDONS: Using repository repository.coldkeys 21:39:02 11.968152 T:1956819888 NOTICE: ADDONS: Using repository repository.awesome 21:39:02 11.968181 T:1956819888 NOTICE: ADDONS: Using repository repository.metalkettle 21:39:02 11.968209 T:1956819888 NOTICE: ADDONS: Using repository repository.entertainmentrepobackup 21:39:02 11.968237 T:1956819888 NOTICE: ADDONS: Using repository repository.teammaniac 21:39:02 12.080811 T:1956819888 NOTICE: Raspberry PI firmware version: Apr 27 2016 11:10:34 Copyright (c) 2012 Broadcom version 9b52ab7b475f4a056658fd2d95d2440b32167390 (clean) (release) 21:39:02 12.080914 T:1956819888 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0 21:39:02 12.080946 T:1956819888 NOTICE: cacheMemBufferSize: 20MB 21:39:02 12.081238 T:1956819888 NOTICE: Config: arm_freq=1200 audio_pwm_mode=1 config_hdmi_boost=5 core_freq=400 desired_osc_freq=0x36ee80 disable_commandline_tags=2 disable_l2cache=1 disable_splash=1 force_eeprom_read=1 force_pwm_open=1 framebuffer_ignore_alpha=1 framebuffer_swap=1 gpu_freq=300 hdmi_channel_map=8 hdmi_edid_file=1 hdmi_force_cec_address=65535 hdmi_force_hotplug=1 hdmi_ignore_cec_init=1 init_uart_clock=0x2dc6c00 lcd_framerate=60 over_voltage_avs=0x2191c pause_burst_frames=1 program_serial_random=1 sdram_freq=450 sdtv_aspect=1 second_boot=1 temp_limit=85 21:39:02 12.081354 T:1956819888 NOTICE: Config: device_tree=- 21:39:02 12.090696 T:1956819888 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi 21:39:02 12.092498 T:1956819888 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz 21:39:02 12.092604 T:1956819888 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz 21:39:02 12.092645 T:1956819888 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz 21:39:02 12.092682 T:1956819888 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz 21:39:02 12.092717 T:1956819888 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz 21:39:02 12.092785 T:1956819888 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz 21:39:02 12.092820 T:1956819888 NOTICE: Found (640x480@60.000000) at 16, setting to RES_DESKTOP at 16 21:39:02 12.092918 T:1956819888 NOTICE: Checking resolution 20 21:39:02 12.220604 T:1956819888 NOTICE: GL_VENDOR = Broadcom 21:39:02 12.220709 T:1956819888 NOTICE: GL_RENDERER = VideoCore IV HW 21:39:02 12.220744 T:1956819888 NOTICE: GL_VERSION = OpenGL ES 2.0 21:39:02 12.220778 T:1956819888 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00 21:39:02 12.220830 T:1956819888 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker 21:39:05 15.552242 T:1956819888 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001) 21:39:06 16.609015 T:1956819888 NOTICE: Running database version Addons20 21:39:06 16.640413 T:1956819888 NOTICE: Running database version ViewModes6 21:39:06 16.652611 T:1956819888 NOTICE: Running database version Textures13 21:39:06 16.681604 T:1956819888 NOTICE: Running database version MyMusic56 21:39:07 16.786718 T:1956819888 NOTICE: Running database version MyVideos99 21:39:07 16.793728 T:1956819888 NOTICE: Running database version TV29 21:39:07 16.798599 T:1956819888 NOTICE: Running database version Epg11 21:39:07 16.801750 T:1956819888 NOTICE: start dvd mediatype detection 21:44:33 18.695194 T:1956819888 WARNING: Trying to add unsupported control type 1 21:44:34 19.197937 T:1956819888 WARNING: Previous line repeats 2 times. 21:44:34 19.198040 T:1956819888 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList" 21:44:34 19.292133 T:1956819888 NOTICE: ActiveAE DSP - starting 21:44:34 19.293770 T:1956819888 NOTICE: UpdateLibraries: Starting video library startup scan 21:44:34 19.300430 T:1956819888 ERROR: ExecuteAsync - Not executing non-existing script /home/osmc/.kodi/addons/script.navi-x/service.py 21:44:34 19.301325 T:1956819888 NOTICE: initialize done 21:44:34 19.301407 T:1956819888 NOTICE: Running the application... 21:44:34 19.317986 T:1956819888 NOTICE: starting zeroconf publishing 21:44:34 19.350351 T:1956819888 NOTICE: WebServer: Started the webserver 21:44:34 19.350498 T:1956819888 NOTICE: starting upnp client 21:44:34 19.353327 T:1478489072 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777 21:44:34 19.353456 T:1478489072 NOTICE: UDP: Listening on port 9777 21:44:34 19.465662 T:1671427056 NOTICE: VideoInfoScanner: Starting scan .. 21:44:34 19.466053 T:1671427056 WARNING: Process directory '/media/Lexar128/' does not exist - skipping scan. 21:44:34 19.466158 T:1671427056 WARNING: Process directory '/media/Lexar128/Antoine/' does not exist - skipping scan. 21:44:34 19.466244 T:1671427056 WARNING: Process directory '/media/Lexar128/Game Of Thrones/' does not exist - skipping scan. 21:44:34 19.466328 T:1671427056 WARNING: Process directory '/media/Lexar128/Modern Family/' does not exist - skipping scan. 21:44:34 19.466410 T:1671427056 WARNING: Process directory '/media/Lexar128/Series/' does not exist - skipping scan. 21:44:35 20.598577 T:1671427056 WARNING: Process directory 'smb://MINT-PC/Torrents/aa/' does not exist - skipping scan.
Any help pls?
