Have just tried to install the above on my Pi 2 āover the top ofā a version compiled in accordance with HarryLās instructions, and it appeared to do a general update first, whereupon I got an error report saying āError while updating {blank}ā. I then got a report saying āError installing armv7-tvheadend-app-osmcā. I then got an Update message āOperations successfully completedā which seems rather misleading!
SƦtter armv7-tvheadend-app-osmc (3.9.0-9) op ā¦
Created symlink from /etc/systemd/system/multi-user.target.wants/tvheadend.service to /lib/systemd/system/tvheadend.service.
Job for tvheadend.service failed. See āsystemctl status tvheadend.serviceā and ājournalctl -xnā for details.
dpkg: fejl under behandling af pakken armv7-tvheadend-app-osmc (āconfigure):
underproces installerede post-installation-script returnerede afslutningsstatus 1
Der opstod fejl under behandlingen:
did a dpkg-reconfigure armv7-tvheadend-app-osmc no help.
first time around the ā/etc/systemd/system/multi-user.target.wants/tvheadend.serviceā was not there after the install did not finish, then did a apt-get remove armv7-tvheadend-app-osmc, and install again⦠then it was thereā¦???
root@osmc:/home/osmc# systemctl status tvheadend.service
ā tvheadend.service - TVHeadend Server
Loaded: loaded (/lib/systemd/system/tvheadend.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since ons 2015-03-25 10:47:28 CET; 4s ago
Process: 25445 ExecStop=/usr/bin/rm /run/tvheadend.pid (code=exited, status=203/EXEC)
Process: 25436 ExecStart=/usr/bin/tvheadend -f -p /run/tvheadend.pid -C -u osmc -g video (code=exited, status=0/SUCCESS)
Main PID: 25437 (code=killed, signal=SEGV)
mar 25 10:47:28 osmc systemd[1]: Unit tvheadend.service entered failed state.
hope this helpsā¦
edit: will try on my second RPI2 wish a fresh osmc
This morning I took a fresh build of OSMC and only installed TVHeadend. I added one mux and it scanned but I am not getting any services found. If I put back the other SD card I have with RaspBMC on it I am getting all the channels.
Sorry to be the bearer of bad news but I am keen to get OSMC working as it looks really good
Just tried a virgin install of RC on my Pi 2 using the RC download image, and after installing Tvheadend server from the App Store I cannot log into x.x.x.x:9981 using either Firefox or IE. However the former gives the message:
āThe connection to the server was reset while the page was loading.ā
which may help pinpoint the problem.
A few of general comments arising from doing a new installation of OSMC & then Tvheadend Server (using the Confluence skin) :
It is not obvious to me that one needs to click on both āInstallā and āApplyā
Clicking on Apply takes you back to the OSMC menu - I would expect it to stay on the TVheadend install page until installation was complete.
Installing something from the App Store always seems to lead to a general update - is this intentional?
There are significant periods when nothing appears to be happening, so one might think it has finished.
However it also is showing no signs of performing a scan - still saying āfalseā under "initial scan complete on the Muxes page, even though āskip initial scanā is false on the Network page. Unlike the version create with your instructions, HarryL, there does not seem to be a scan command and many other details of the are different.
So it doesnāt look as if the new App Store version for Pi 2 is much better.
Which version did @HarryL build? I must admit that on older versions scanning seemed more intuitive and on newer ones I think scanning is meant to be āpassiveā but I have had troubles with this.
In my case, and as with most others, I am having no trouble with the scanning (well it says it has completed the initial scan)⦠the issue is that the initial scan finds no Services. With Raspbmc and Openelec Services are found without issue.
