OSMC RC2: hangs after around 8 hours
Hello,
Just wanted to provide some feedback on what might be a bug.
Using RC2 (upgraded from RC1).
OSMC seems to be hanging.
I can ssh and reboot.
dmesg is below. It starts at 3:52pm.
I was playing Live TV (radio) since around 8am - so exactly 8 hours.
Thanks.
Best regards,
Niall.
[Wed Apr 15 15:52:53 2015] INFO: task kworker/0:2:3176 blocked for more than 120 seconds.
[Wed Apr 15 15:52:53 2015] Not tainted 3.18.10-1-osmc #1
[Wed Apr 15 15:52:53 2015] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[Wed Apr 15 15:52:53 2015] kworker/0:2 D c06b1994 0 3176 2 0x00000000
[Wed Apr 15 15:52:53 2015] Workqueue: events od_dbs_timer
[Wed Apr 15 15:52:53 2015] [] (__schedule) from [] (schedule+0x40/0x8c)
[Wed Apr 15 15:52:53 2015] [] (schedule) from [] (schedule_timeout+0x214/0x2bc)
[Wed Apr 15 15:52:53 2015] [] (schedule_timeout) from [] (__down+0x90/0xd4)
[Wed Apr 15 15:52:53 2015] [] (__down) from [] (down+0xc0/0xc4)
[Wed Apr 15 15:52:53 2015] [] (down) from [] (bcm_mailbox_property+0x178/0x2b4)
[Wed Apr 15 15:52:53 2015] [] (bcm_mailbox_property) from [] (bcm2835_cpufreq_driver_target_index+0x70/0xcc)
[Wed Apr 15 15:52:53 2015] [] (bcm2835_cpufreq_driver_target_index) from [] (__cpufreq_driver_target+0x15c/0x2bc)
[Wed Apr 15 15:52:53 2015] [] (__cpufreq_driver_target) from [] (od_check_cpu+0x80/0x104)
[Wed Apr 15 15:52:53 2015] [] (od_check_cpu) from [] (dbs_check_cpu+0x108/0x170)
[Wed Apr 15 15:52:53 2015] [] (dbs_check_cpu) from [] (od_dbs_timer+0x70/0xfc)
[Wed Apr 15 15:52:53 2015] [] (od_dbs_timer) from [] (process_one_work+0x164/0x52c)
[Wed Apr 15 15:52:53 2015] [] (process_one_work) from [] (worker_thread+0x44/0x664)
[Wed Apr 15 15:52:53 2015] [] (worker_thread) from [] (kthread+0x170/0x18c)
[Wed Apr 15 15:52:53 2015] [] (kthread) from [] (ret_from_fork+0x14/0x20)
[Wed Apr 15 15:54:53 2015] INFO: task kworker/0:2:3176 blocked for more than 120 seconds.
[Wed Apr 15 15:54:53 2015] Not tainted 3.18.10-1-osmc #1
[Wed Apr 15 15:54:53 2015] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
update: a reboot wasn’t enough. Wifi didn’t start, and OSMC didn’t start.
Had to power cycle. Now everything work fine again.
I will see tomorrow if it happens again after 8 hours of use.
