Hello,
I just set a manual update but without success, it still does not work
EDIT
It’s good it works effectively, it was necessary that I active “SPI” parameter in OSMC unlike before.
Thank you
Hello,
EDIT
Thank you
hello, I encounter some problems since that update.
LED flashes quite often as if there were interference.
I restored an old picture and the problem disappears …
So it comes right updating …
Thank you
Surprising no one else experiences this flash problem.
With my backup before the update I really have not this problem.
Maybe everyone is still vacant
Works fine for me using SPI and ws2801 driver.
Does changing the SPI bus speed make any difference ?
Hello,
Thank you for your message, not by changing the speed chnagement
I can confirm this too. Since the update I notice sporadic flicker (flash) with lightberry HD too.
it reassures me to not be the only
I hope there is a solution
hello, this problem is resolved it since? (flash)
Same problem here after reinstall osmc (10.2015)
Only one LED is on …
Any solutions?
