Hello,
I have a problem with RC3, Hyperion does not work: frowning:
I’m active in the SPI configuration OSMC and I also added the line in the /boot/config.txt file.
I transfer my hyperion.config.json file in the opt / Hyperion / config
Hyperion is installed correctly but the LEDs still do not turn on.
Even with Android application that does not work well when it connects.
Before passing under OSMC, I was on Raspbian + 14.2 Kodi and Hyperion worked fine.
PS: I use a Lightberry 56 Leds
Thank you in advance for your help, I’d really like to stay under OSMC: smile:
Same configuration with Lightberry HD is working here. I didn’t enable SPI true OSMC Settings (didn’t work) only in config file. If you can’t connect with your APP it seems there is no Hyperion server running yet.
Did you run this Lightberry setup before already or is it new (never used befor
If you want, I can send you my config files. Maybe there is something wrong in your files.
Alternatively you can download a preconfigured image (http://lightberry.eu/#download) from lightberry and try out if your hardware is working at all. I never installed them myself, coz for me it was working always with OSMC.
Once I used OSMC Settings to enable SPI and it stopped working for me. After I switched it off again in OSMC Settings, it started working again. Maybe it’s just with my installation. I didn’t mean don’t use it in general. Just trying to help with my own expierience.
I guess it’s not a good idea to use OSMC Settings to enable SPI when dtparam=spi=on is already written inside config.txt
Check the following setting -> Go to System/settings/services/remote control/ and enable both option in there. This will allow hyperion to remote control kodi. Maybe this it the issue.
SPI is always activated in the config.txt file.
If I OSMC active in the menu that does not change even after a reboot.
What set apart reinstall everything?
Here log
Thank you
root@osmc:~# sudo /usr/bin/hyperiond /etc/hyperion.config.json
Application build time: Mar 6 2015 20:57:44
QCoreApplication initialised
Selected configuration file: /etc/hyperion.config.json
ColorTransform 'default' => [0; 53]
Device configuration:
"colorOrder" : "rgb",
"name" : "MyPi",
"output" : "/dev/spidev0.0",
"rate" : 1000000,
"type" : "lightberry"
Failed to open device('/dev/spidev0.0')
Black border threshold set to 0.01 (3)
Creating linear smoothing
Created linear-smoothing(interval_ms=50;settlingTime_ms=200;updateDelay=0
Effect loaded: Knight rider
Effect loaded: Blue mood blobs
Effect loaded: Cold mood blobs
Effect loaded: Full color mood blobs
Effect loaded: Green mood blobs
Effect loaded: Red mood blobs
Effect loaded: Warm mood blobs
Effect loaded: Rainbow mood
Effect loaded: Rainbow swirl fast
Effect loaded: Snake
Effect loaded: Strobe blue
Effect loaded: Strobe Raspbmc
Effect loaded: Strobe white
Initializing Python interpreter
Hyperion created and initialised
run effect Rainbow swirl fast on channel 0
Boot sequence(Rainbow swirl fast) created and started
XBMC video checker created and started
Display opened with resolution: 1920x1080
Frame grabber created and started
terminate called after throwing an instance of 'std::runtime_error'
what(): Json server could not bind to port
