17:08:33.412 T:1959018496 FATAL: addon 'xbmc.addon' not installed or not enabled.
17:08:33.412 T:1959018496 FATAL: CServiceManager::Init: Unable to start CAddonMgr
You seem to be familiar with APT based on your Terminal history, so I’d suggest running a dist-upgrade.
sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
And
sudo apt-get update
E: The method driver /usr/lib/apt/methods/http could not be found.
and
sudo apt-get install apt-transport-https
E: Unable to locate package apt-transport-https
I remove already remove all files or folder on /etc/apt/sources.list.d
Dec 07 23:39:54 wohnmucke mediacenter[387]: /usr/lib/kodi/kodi.bin: error while loading shared libraries: libasn1util.so.0: cannot open shared object file: No such file or directory
Dec 07 23:39:54 wohnmucke sudo[478]: pam_unix(sudo:session): session closed for user osmc
Dec 07 23:39:54 wohnmucke mediacenter[387]: Kodi exited with return code 127 after 0 hours, 0 minutes and 0 seconds
Your system has been going for quite a long time (since May 2015), so you’ve had a good run.
You can reinstall the missing library and see if that fixes the problem:
Some SD cards are not genuine or have a lower capacity than advertised. Some simply fail over time.
Symptoms of SD cards not working correctly are:
Read-only behaviour, or changes made not persisting
A filesystem corruption error
Symptoms of counterfeit SD cards are:
Writing works until a certain filesystem size is reached, thereafter, writes seem to cause issues where existing data is lost or newly written data is not preserved.
SD card fails after a short amount of time.
Counterfeit cards are usually found on Amazon and eBay.
SD cards have a limited lifespan. I recommend you change SD card and suspect that issues will no longer persist with a good card. If you would like to be a good quality SD card purpose manufactured for OSMC, then you can find one in the Store.
