Apologies if this is now where this goes. My OSMC remote was jammed in a spot with several buttons pushed all night. My 4k now doesn’t respond to any button presses. I have removed the battery and put it back in and rebooted the device and still nothing. The battery seems to still be putting out 2.7V. Any ideas?
Thanks!
Try re-pairing it by holding Home and OK. Make sure there’s no debris in between the buttons.
If that’s open-circuit, you may find it’s a lot less when on load. Have you tried a new battery?
I tried holding both for several seconds and a quick simultaneous press and no luck.
That will be my next step. Grabbing one later today.
Our new remote warns low battery on 2.2V. But yeah, I think the battery is drained and multiple, constant battery presses drained it quickly
New battery fixed me right up. Good to go!
Glad to hear. We added a low battery warning on the new remote to try and give users a warning when the battery is dying
