Hi I´ve ordered (#28158) a OSMC remote control to control a HTPC. Unfortunately it seems to stop working. The batterie is good. I also get a message that “USB Keyboard Mouse” is installed & ready if I plug in the transmitter. But I can´t control e.g. Kodi with the remote. Also the remote doesn´t work plug&play with the Vero4K. I don´t know, what should I do now?
- Remove the USB from Vero 4K / Pi
- Hold Home and OK button for 5 seconds or so, then the blue LED will keep flashing.
- Plug in the USB receiver and the LED should flash 3 times after 5 seconds, indicating successful pairing.
- Power off Vero 4K / Pi for 2 minutes. Turn it back on. The remote should now work.
Unfortunately it doesn´t pair after I plug in the USB receiver. The blue LED is fixed on but it doesn´t blink 3 times.
Can you change the battery?
Thanks a lot, now it works. The trick was to remove the battery (~10 Minutes). After that I followed your pairing guide. During pairing I had to wait about 30 seconds (not 5 seconds) but than the blue led from the remote flashed 3x quick. Now it works.
That suggests to me that your battery is getting quite low.
Hi it only worked one time. Now it doesn´t work at all. I´ve put a new battery in, the pairing (3xflash) only works after 50 seconds. But after off/on from the Vero4K+ the remote doesn´t work at all. I think it´s defect. Please tell me the adress where to send it then you can have a look at it.
Do you still see a blue light when you press a button?
No
Please start a support request with order details.
Did you try the App remote control? The official kodi app is ok called Kore. The other one is better called Yatse. I also use a separate app to control my Samsung TV, there is also another app for my AVR but I don’t use it.
Hi I´ve made a ticket and answered 2020-03-25 12:20:39 but the ticket status is still open and my problem isn´t solved. Could somebody from the support team please look at this ticket? I made logs and uploaded them. Thanks, Michael.
I will check this for you shortly.
I’ve updated the ticket with some details
Could anybody from the support team have a look at my ticket, please? It´s still open and I want to reuse the Vero4K+ hardware as soon as possible. In fact I´m trying to get this remote control to work since 1 month ago.
Hi Michael – I already shipped you a new one last week.
I’m keeping the ticket open until you confirm that it is working.
Hi the new remote is here and working flawless. Thanks a lot. Now I can use my Vero4K+ again.
Should I send you the defectice remote to you or can I throw it away?
Please just recycle it responsibly. I am glad this is resolved.
