I believe I have the first generation remote and I am setting it up to work with Kodi on PopOS!/Ubuntu. I have installed the custom .deb packages found at: http://ftp.fau.de/osmc/osmc/apt/pool/main/a/amd* and for the most part the remote is working.
I have noticed the info and menu buttons do not function and would like to try and get them working but a recent post about the remotes specifically mentions these keys as troublesome:
I am wondering if it will be possible for me to make these keys do anything at all. I have a custom keymap.xml file that I am attempting to use to make them work. The examples I have found here: Volume on Up/Down buttons for OSMC remote control in KODI · GitHub work as I want them too, but I cannot get those two buttons to respond at all.
To get those two buttons working on that remote it has to either be setup through eventlircd or those two keys can be remapped at the OS level, The former is how it works in our current stable and previous builds of OSMC, and the latter is what we are moving to with our long-press update. I’m a nix noob but I think Ubuntu is using a different system to hard remap keys than Debian so I can’t give info for that. You would want to remap to “i” and “c” though… unless you use a non-english keyboard input in which case things get a lot more complicated.
Happy to test a new approach if that helps, I am not making much progress unfortunately.
Using irw I get key presses registered as KEY_KPRIGHTPAREN and KEY_KPLEFTPAREN for those two buttons, I can see them seen as the same thing in the Kodi log too. However the OSMC remote .evmap file in /etc/eventlircd.d does not contain any of those strings and lircd.conf doesn’t seem to match up either:
cat /etc/lirc/lircd.conf
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0-pre1(default) on Thu Jan 8 11:26:07 2015
# contributed by Dilligaf
# brand: OSMC
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name OSMC
bits 5
flags RC5|CONST_LENGTH
eps 30
aeps 100
one 872 807
zero 872 807
plead 886
pre_data_bits 8
pre_data 0x84
gap 107676
toggle_bit_mask 0x800
begin codes
KEY_HOME 0x0F
KEY_INFO 0x10
KEY_UP 0x11
KEY_DOWN 0x13
KEY_LEFT 0x15
KEY_RIGHT 0x12
KEY_OK 0x14
KEY_BACK 0x16
KEY_TITLE 0x17
KEY_PLAYPAUSE 0x18
KEY_STOP 0x19
KEY_REWIND 0x1A
KEY_FASTFORWARD 0x1B
end codes
end remote
Using the advice here for capturing and handling those LIRC events https://kodi.wiki/view/LIRC doesn’t seem to be working in Kodi either.
otherwise you would need to also grab out of the staging build you pulled that hwdb file from /usr/share/kodi/system/peripherals.xml /usr/share/kodi/system/keymaps/osmc_classic.xml /usr/share/kodi/system/keymaps/osmc/osmc_remote.xml
Which adds that remote to the peripherals system and allows the keymap in that osmc folder to load. The osmc_classic keymap just fixes the maps for my rekeying to the bracket keys (for language fixes). The mapping for that is in the osmc_remote file but I needed something to fallback to in case someone decided to turn off my custom keymap in the peripherals settings.
If you were looking at our current or former versions you would see the eventlircd setup. Your on staging where we already disabled that for these remotes.
I posted a generic one above for the remote in question, which is the only one that has keys that can’t be fixed with just a keymap. If you want the next couple of remotes covered with a tweak to help out the French and Germans feel free to make an easy install to dump this to /etc/udev/hwdb.d/osmcrf.hwdb
