I have a RP2 with 8Gb flash microSD. My Kodi version is 16.x. I don’t remember well.
Yesterday I began to have problems in Kodi because several times Kodi was frozen and I unplugged the power cord. Never it happened in the past. Today I went to play a movie and Kodi was frozen again. I rebooted it and the sad face showed up and never left.
I have exported the log and I don’t get find an error on it. Probably RP was updating or something like that and got an error. By the way, it doesn’t show any error message, just the sad face. Could you help me?
Thank you for answering so quickly. I did that but nothing happened. Then, I did: apt-get update, apt-get upgrade and finally apt-get dist-upgrade and OS was upgraded but the result is always the same.
I have access by ssh now. What files do you new to review the problem? I would like don’t reinstall because I don’t have any kodi backup.
it is not the first time I do that and never one problem during five years. I am sure my problem will be resolved. Thank you for your time I hope there are people who had the same problem like me and they can help me.
OSMC uses the APT packaging system. As such, OSMC can be fully upgraded via the command line by running the following two commands:
sudo apt-get update
sudo apt-get dist-upgrade
Warning: Avoid running sudo apt-get upgrade as it won’t fully upgrade your system. Be sure to run the above commands instead. Running the former command can break your OSMC installation.
We recommend however that users upgrade via My OSMC. Upgrading via My OSMC will still ensure that all Debian packages are upgraded.
Well as @ActionA and @Toast said not really a logical explanation and I only can urge you to believe in the advices given on the forum and not use apt-get upgrade in the future.
Anyhow your current problem is much more simple and you should have found it yourself. You ran out of space on your root partition
Were do you see that? In the log that you uploaded you only had 0 Mbit free on /
Also even 300M is at the edge when upgrading.
And stop saying that you successfully use apt-get upgrade and just stop doing so!
Nothing more to say. Your knowledge with this problem is limited and you’re not giving me anything new. I hope new responses from people with the same problem that I
