Is OSMC Scope available for Kodi 21.1? I had it on Kodi 21, but when I updated to 21.1, I got a message saying it wasn’t compatible? This is on PC. I tried adding the repository following this guide, but it fails to add it for some reason. The screen locks up when I add it and hit OK.
The scope skin is available for v21, same as all other versions of our skin. Not sure why installing the repo would cause issues. Could you post some logs trying to install the repo?
Will check this shortly.
I think the issue may be the name. @chillbo, you still have it as:
<addon id="skin.osmc.scope" version="21.1.0" name="OSMC Skin" provider-name="OSMC">
I think name should probably be OSMC Scope Skin. Perhaps the duplicate naming causes an issue.
While you are at it, can you check addon.xml. The 16:9, 4:3 and scope skins have an optional dependency on Skin Shortcuts, but the main skin itself does not.
Will check shortly. Must’ve buggered that up.
@Chillbo , Any update on this?
8hrs was a wait already too long? ![]()
It should be fixed now. Please check for addon updates and see whether all four skins are showing up in the OSMC Skin repo now. ![]()
@Chillbo I think you need to bump the version in the addon.xml files as well or Kodi won’t refresh the repository.
Could you try again now, please? ![]()
It’s there. Thank you so much for updating the skin. I use a scope screen with my projector and this skin is the perfect solution.
