Let me know if you need more logs than this.
19:42:01 167.696060 T:1750807584 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
19:42:01 167.696457 T:1750807584 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ========
19:42:01 167.696823 T:1750807584 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 15.2
19:42:01 168.045639 T:1750807584 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.14
19:42:01 168.047440 T:1750807584 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Platform: Linux/RPi
19:42:02 168.747360 T:1649882144 NOTICE: StorageServer Module loaded RUN
19:42:02 168.747971 T:1649882144 NOTICE: StorageClient-2.5.4 Starting server
19:42:02 169.237152 T:1536947232 NOTICE: -->Python Interpreter Initialized<--
19:42:05 172.325790 T:1692087328 NOTICE: service.libraryautoupdate-0.9.8 : Creating timer for Video Library
19:42:05 172.567993 T:1742418976 NOTICE: script.grab.fanart: Grab Fanart Service Started
19:42:11 178.219589 T:1675310112 NOTICE: Thread LanguageInvoker start, auto delete: false
19:42:13 179.909943 T:1675310112 NOTICE: -->Python Interpreter Initialized<--
19:42:17 184.040604 T:1784362016 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ValueError'>
Error Contents: invalid literal for int() with base 10: ''
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/service.py", line 38, in <module>
m = update_service.Main()
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.py", line 244, in __init__
self._daemon()
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/CompLogger.py", line 61, in wrapper
func(*args, **kwargs)
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.py", line 284, in _daemon
self.position_icon()
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.py", line 529, in position_icon
screen_width = int(screen_width)
ValueError: invalid literal for int() with base 10: ''
-->End of Python script error report<--
19:43:18 244.749405 T:1658270752 NOTICE: Thread JobWorker start, auto delete: true
19:46:00 407.186005 T:1957773872 NOTICE: Previous line repeats 5 times.
19:46:00 407.186218 T:1957773872 ERROR: GetDirectory - Error getting /usr/share/kodi/sounds/
19:46:00 407.186310 T:1957773872 ERROR: GetDirectory - Error getting special://xbmc/sounds/
19:46:00 407.232727 T:1957773872 ERROR: GetDirectory - Error getting /usr/share/kodi/sounds/
19:46:00 407.232910 T:1957773872 ERROR: GetDirectory - Error getting special://xbmc/sounds/
19:46:18 425.035736 T:1480586272 NOTICE: Thread LanguageInvoker start, auto delete: false
19:46:18 425.134003 T:1480586272 NOTICE: -->Python Interpreter Initialized<--
19:46:19 426.482239 T:1666921504 ERROR: EXCEPTION: Non-Existent Control 300
19:46:28 434.657440 T:1369437216 NOTICE: Thread LanguageInvoker start, auto delete: false
19:46:28 434.736115 T:1369437216 NOTICE: -->Python Interpreter Initialized<--
19:46:28 434.736481 T:1369437216 WARNING: CPythonInvoker(19): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:46:28 434.911438 T:1369437216 NOTICE: OSMC settings sending response, update
19:46:28 434.914764 T:1369437216 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'socket.error'>
Error Contents: (2, 'No such file or directory')
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/call_parent.py", line 18, in <module>
sock.connect(address)
File "/usr/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
error: (2, 'No such file or directory')
19:46:46 453.022675 T:1536947232 NOTICE: Thread LanguageInvoker start, auto delete: false
19:46:46 453.098175 T:1536947232 NOTICE: -->Python Interpreter Initialized<--
19:46:46 453.098541 T:1536947232 WARNING: CPythonInvoker(20): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:46:46 453.274780 T:1536947232 NOTICE: OSMC settings sending response, update
19:46:46 453.278015 T:1536947232 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Update: Rebooting again seemed to fix the 2nd type of error, where it wouldn’t scan for updates. Don’t know how to test the first.
