Hi there !
I used raspbmc for a few years and was thrilled to try the new OSMC ! After finishing the scans etc…, everything works fine ! except just a little esthetic… On the onld confluence skin, when you were in the TV show section, it was possible to push “left” and a menu was appearing letting you chose between different layouts. I dont know if its me, but in the OSMC skin, the menu dont even show up ! Is there a different key to press, because i would really like to change the default layout.
Thank you !
Djosimd
