I’m having trouble with the Movies home screen widget.
I want it to display unwatched movies only, and like for TV-series, I assumed that the “Recent Movies” setting did just that. It seemed to work right after installing OSMC a couple of days ago, but now it doesn’t update to reflect changes in the watched-status of my movies! Tried the other settings for the Movies widget, but no luck! The widget doesn’t populate.
Before OSMC I used the Amber skin in Raspbmc, and never had this problem. In Amber “Recent Movies” always diplayed unwatched movies and updated almost instantaneouly.
For TV-series the widget works as expected, i.e “Recent episodes” displays unwatched episodes and also updates immediatly.
Any others having the same problem?
Would a log be helpful in this case? Which log would be of interest?
Rpi1 512 MB
OSMC stable
OSMC skin
