Hey Guys,
Everytime I wake up my device (Vero4k+) it‘s slowing down so much, I have to reboot. Kodi CPU usage is over 200% then…
Even if I put the Device to sleep for only 5 seconds this thing happens and I just can‘t help myself and don‘t know what to do
Any suggestions?
Thank you for your help!
Log: https://paste.osmc.tv/tebivojiki
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Definitely need to see some logs here, as well as how you’re measuring CPU use.
Just wondered why I can‘t upload the log directly an completely forgot about the uploader
The CPU usage I was writing about is just what the error logger is showing to me. Log added to the initial posting
Regards
Alex
I would just start disabling add-ons until you found the culprit.
U think it’s up to an addon? I mean it happens really only after waking up the sleeping device.
Isn’t there a way to see how many resources are used by an addon (like a taskmanager)?
After looking at your log, yes.
If you wanted to do a quick isolation of your setup from the rest of the system you could SSH in and…
To make a fresh Kodi setup
mv ~/.kodi ~/kodi.bak
To restore your original setup:
mv ~/.kodi ~/kodi.virgin
mv ~/kodi.bak ~/.kodi
