Hi guys, I succesfully login into my OSMC installation (Rp2) with default credentials, but when I try to change the password using sudo passwd I get a confirm message that it tells me that the pass has been changed, but when I restart the board I can enter only using the default previous password OSMC.
passwd by itself will work to change the osmc user password - the error you’re reporting indicates a problem with the system. (Although I have no idea what, as I’ve never seen that error before)
Than please mark this thread as “solved” there is a easy tick that you just can set on your last comment.
Actually if you can set the “solved” tag for more than 1 comment do it on your last one and the one where we gave you the idea of not using sudo.
