I recently bought the black OSMC remote from the Store, but would like to remap a few of the buttons via a keymap file. Does anyone know what the various button IDs are? Once I know this, I can map them to Kodi functions as per their FAQ.
Many thanks in advance.
Easiest way to do that is via keymapper addon
I think I came across that years ago, but forgot about it - I’ll install it an have a play. Cheers for the tip!
A wee and quick update to fzinken - thanks so much again for your advice: I used to program my remote by hand, but this add-on is so much easier! I forgot about it, but revisiting it, I find it sorts everything out as I want. I’ve been using XBMC/Kodi since 2007, and love the fact that just when you think you have it licked, someone shows you more to learn!
Cheers pal : )
