Hi, trying to set up tv at a friend’s. OSMC tuner, OSMC hub, Vero 4k. TvH isn’t showing the tuner.
So far tried swapping the usb ports on the Vero, and connecting the tuner directly to the Vero to rule out the hub being faulty. The latter setup is what’s in the log.
https://paste.osmc.tv/etacojadih
Thanks.
Sorry for the late reply.
Can you try plug the USB stick in to a PC and see if it shows up in Device Manager?
I can see that the device has been recognised previously as it’s listed during keymapping when Kodi starts.
Thanks, not showing up in Windows so I guess it’s dead?
I’ve got a spare so will try that next week.
Try give the USB connector a bit of wiggle.
