Pi3 with OSMC remote and OSMC TV dongle (and 2.5A psu) running OSMC March 2018.
I’m very basic with linux, just enough to break things…
TVHeadend installed and running OK, but on cold boot it only lists the Realtek tuner (DVB-T) under Config > DVB Inputs > TV Adaptors. My workaround is
sudo service tvheadend stop
rm /home/osmc/.hts/tvheadend/input/linuxdvb/adapters/9d84dad05c885fe8d8a91db0bf0c47ce
sudo service tvheadend start
ie deleting the adaptor config. TVH then lists all 3 tuners, I just have to re-enable them and associate with the Network. I’m then set until a reboot.
dmesg has these
6.304607] usbcore: registered new interface driver brcmfmac
[ 6.352646] usb 1-1.5: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 6.352692] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[ 6.392653] i2c i2c-3: Added multiplexed i2c bus 4
[ 6.392671] rtl2832 3-0010: Realtek RTL2832 successfully attached
[ 6.418001] mn88473 3-0018: Panasonic MN88473 successfully identified
[ 6.418135] usb 1-1.5: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))…
[ 6.418403] usb 1-1.5: DVB: registering adapter 0 frontend 1 (Panasonic MN88473)…
and then this warning…
usb 1-1.5: DVB: adapter 0 frontend 1 frequency 0 out of range (42000000..1002000000)
…which is weird because that’s the Realtek tuner, and none of my muxes are out of range.
Let me know if there’s more detail/logs needed. Cheers.
